Question about Cell Phones
Milwaukee speaker not connecting to blue tooth. Any ideas?
    Master:
  • 534 Answers
I had that problem until I turned off other nearby Bluetooth devices.
Posted on May 04, 2017
  • 383 Answers
SOURCE: How do I disconnect my phone from another Blue Tooth device?
Go to active devices menu in the bluetooth menu and delete any devices listed there and start find new device ... it should work fine ...
Posted on Oct 09, 2008
  • 10 Answers
SOURCE: Can I hook a blue Tooth speaker to my model #ld320ss8
I do not believe your model of TV has bluetooth support.
You will have to connect it with an auxiliary cable, or use other speakers with the appropriate cable.
You can use wireless speakers, but they would come with a receive that would have to be connect to the TV with a cable.
Posted on Dec 18, 2014
mike0862
  • 5630 Answers
SOURCE: Want to purchase a 2 nd soma speaker but will it bluetooth connect separate from 1st speaker .want to use speakers in separate rooms playing off one blue tooth feed
No, you will only be able to connect 1 device to 1 bluetooth speaker, but you could connect the device to 1 speaker using the line in jack and then connect to the other speaker using the bluetooth!
Posted on Dec 28, 2014
Terry Corrow
  • 10875 Answers
SOURCE: what is the pairing code when trying to blue tooth a Modal Blue tooth speaker? the model is MD-SPBT01
http://images-usweb.bbystatic.com/modal/files/MD-SPBT01_Blue-Tooth-Speaker_Quick-Setup-Guide_English.pdf
25568178-luwwge4czbaizljvp4ehh2hd-2-2.png there is no code,choose the device
unless the device needs a code,then it will show one
Posted on Mar 14, 2015
  • 14 Answers
SOURCE: How do I connect my soundlogic blue tooth speaker to my iphone
Connecting any device to an iPhone via bluetooth is a fairly straightforward process:
1) Make sure your device (soundlogic speaker, in this case) is on and in "discoverable" mode. Your speaker should have come with instructions on how to do this; It's a different process per device, so I can't offer anything specific in regards to doing this, sorry.
2) Go into the Settings on your iPhone, then click on "Bluetooth". If Bluetooth isn't turned on, turn it on, then click on your device under "Devices". If you don't see it, make sure you're close enough to the speaker and that the speaker is in "Discoverable" mode. Your phone will pair itself with your speaker, and from this point on, your phone should automatically connect with your speaker anytime both your speaker is on and your phone is on with bluetooth enabled. Hope this helps!
Posted on Apr 15, 2015
My Bluetooth and speaker connect but it wont stay on after one or two songs it keeps shuting down kicking my Bluetooth off on my phone
Teri,
I can't explain why this might work
but try this.
Disconnect the speaker from the phone's blue tooth by unpairing it
then reconnect the speaker by pairing it to the phone again for a fresh reconnection via blue tooth..
Had this issue with a Jabra blue tooth speaker on my wife's mobile phone was doing the exact same symptoms !
It was very very annoying but doing the pairing again fixed it .
Hasn't cut out since pairing it again !
Feb 03, 2017 | Cell Phones
USING SOUND BAR FOR BLOWN SPEAKER ON TV
If you use Blue Tooth, wires are not needed.
Press the manual Mode button to find blue tooth mode. Green light will display. Blue Tooth is a general signal sent out. There is no specific setting for TV.
If your TV is sending out a Blue Tooth signal, it should find the speaker automatically. http://www.ematic.us/sites/default/files/ESB212_Manual_01_0.pdf
Check your TV's Blue Tooth settings and have it scan. Default password/code for the sound bar is 0000.
Also check your remote batteries. Sometimes they are installed backwards by the factory so they won't go dead.
Mar 22, 2016 | Ematic ESB212 Wireless SoundBar with...
When i try to pair with my galaxy tab s through bluetooth the tab goes through the process of connecting but doesnt pair however my galaxy s5 phone pairs immeditely ?
  • Your issue is that you can only connect one mobile or tab to a blue tooth.
  • It only accepts one device at a time.
  • You need to connect one to your blue tooth in your vehicle and try something like a blue tooth pill or blue tooth speaker.
  • I have had this problem with my Parrot car kit.
  • Hope this helps. Russell
Nov 22, 2015 | Cell Phones
Can not connect blue tooth to JBL speaker
Check the bluetooth protocol stacks of both devices are compatible.
Wiki on blue tooth stacks:
List of Bluetooth protocols
Mar 13, 2015 | Opt-6 Products iPhone Apps
Can I connect bose speaker to Sony blue ray via blue tooth
Is your Bose speaker a Bluetooth speaker ? Does your Sony blue ray player have Bluetooth ? You can connect the two only if Both are Bluetooth devices.
Feb 15, 2015 | Sony Televison & Video
Dec 17, 2014 | Sylvania Televison & Video
How do you connect the onn mini speaker model BTS108
Search for the speaker from the device being used to connect!
Oct 15, 2014 | Audio Players & Recorders
Can I connect to Vizio TV with blue tooth
If your ear buds have been connected to any device before your TV then it won't work. If you want to connect it to your TV you turn on your headphones, hold the call button for 3 seconds, and you will see ur light flash and connect it to your TV. If this didn't help then go to the manual and check how to connect your headphones to your TV.
May 24, 2014 | AUVIO Bluetooth Headphones
No sound from speakers, loose connection in green jack wire.
Yeah man I have the same problem!
I guess I will just buy a new jack!
May 27, 2009 | Logitech Z-640 5.1 6-Piece Home Theater...
Wireless speakers not communicating to Receiver
Speakers have a unique RF frequency that needs to pair with the receiver (kind of like a blue tooth headset with a cell phone). At times, the signal may reset, so, you may have to go through the initial pairing sequence. Try this:
1. Unplug rear speakers
2. Make sure the sound signal connector is plugged in to the back of the system properly.
3. Press and hold the ID button for 3 seconds until the blue LED light flickers.
4. Connect the power chord to the rear speakers.
May 03, 2009 | NexxTech DP3222 DVD Player
Cell Phones Logo
42 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
