Question about Garden
My Dixon ZTR engine seems to be running at full speed, but there is not enough power to get up a small hill
  • 313 Answers
SOURCE: Riding lawn mow
give as the model so we can help.
Posted on Jun 12, 2008
  • 40 Answers
SOURCE: Ryobi RBL30MVA petrol blower problem
if this is a brand new I would ask is the gas oil mixture fresh and of the proper ratio. most use 40-1
if this is not brand new look and see if the muffler could be clogged up. a common problem is the spark arrestor screen gets clogged up with carbon deposits.
Posted on Mar 11, 2009
rockitman187
  • 2559 Answers
SOURCE: Steering Adjustment for a Dixon ZTR
Try the 3310 as pictured below
Posted on May 31, 2009
rockitman187
  • 2559 Answers
SOURCE: I have a Dixon ZTR steeering problem
We will find it no matter where it is posted
  • 61 Answers
SOURCE: where on the Dixon ztr 5421 do you check the
there should be a sight glass or a dip stick in the
hydraulic tank.
Posted on Sep 06, 2009
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Carb problems
check and see if all your carb jets or clean sound like some dirt got into one
Jul 07, 2014 | Dixon Ticonderoga NEW 52" DIXON ZERO TURN...
Why Dixon lawnmower goes slow?
Yes they should be a sealed system. Check the fluid level in the tank.
Sep 16, 2017 | Garden
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
How to remove small sprocket and chain on a Dixon ZTR 4422
Try using a open end wrench, there is a chance that the rod will slide the other way when you undo the nut which will allow the nut to come off and not his the carriage.
You can check by loosening the nut about enough to get a pry bar in then see if you can push the nut back to the gear, it it moves that means you can get it off.
Apr 14, 2013 | Garden
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Should I buy a used 311 Dixon ZTR for my 1/2 acre yard?
Never buy one. Ever. Unless you have a mechanic from Dixon that will live with you to fix it every time you turn it on. I HATE it. If it isn't one thing, it is something else. Will not run. Tires a worthless. Seven thousand dollars of ****. Just call and complain and see if anyone cares. Nope. Cannot keep battery that works more than a summer. Nothing but trouble. Cannot get anyone west of the Mississippi to come to your house to service it. Must pull it in a trailer to get it serviced. Over all --junk. No one helps from Dixon, no one cares. Cannot wait until they go out of business. A sling blade would work better. Please get sheep or goats. Much more reliable.
Mar 07, 2010 | Briggs & Stratton Garden
Can't get speed go up hills
That's often the sign of a clogged fuel filter. Running on level ground or not trying to accelerate hard, enough fuel can get through for the engine to make the power you need. But when you try to punch it to accelerate quickly, or you try to go up a hill (basically anytime max power is needed), the car can't flow enough fuel to the engine to make that power, and the car seems to fall on its face. Change your fuel filter out and see if that helps.
Oct 06, 2008 | 2002 Mazda Millenia
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
