SOURCE: Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
SOURCE: How do I disconnect my phone from another Blue Tooth device?
Go to active devices menu in the bluetooth menu and delete any devices listed there and start find new device ... it should work fine ...
SOURCE: Can I hook a blue Tooth speaker to my model #ld320ss8
I do not believe your model of TV has bluetooth support.
You will have to connect it with an auxiliary cable, or use other speakers with the appropriate cable.
You can use wireless speakers, but they would come with a receive that would have to be connect to the TV with a cable.
SOURCE: milwaukee job site radio
The transformer needs to be replaced. 120VAC to 15VAC. Take a look on amazon for it, here: Amazon com 15VAC transformers. Wish you best of luck.
Brust
http://images-usweb.bbystatic.com/modal/files/MD-SPBT01_Blue-Tooth-Speaker_Quick-Setup-Guide_English.pdf
there is no code,choose the device
unless the device needs a code,then it will show one
