Question about Dryers
My dryer runs hot and then the next load is cold. I had the heating element and thermostats checked and they are fine.
  • 172 Answers
SOURCE: Tumble dryer not heating
Hi irshaad,
If all the componants are good, you are loosing voltage somewhere. Check the voltage to the dryer. If you do not have 220 volts then you have a blown fuse or a kicked breaker in your fuse box. This would allow only 110 volts to get to the dryer and the dryer would run and not heat. If you have the correct voltage to the dryer check the connections on the terminal block and the wires to the block. Before going any further than that I would really rather have your model so I could guide you correctly. Good luck and I really hope this will FixYa.
Mike Anderson
Posted on Jun 03, 2008
SOURCE: It runs, but no heat
I am having the same problem. Whirlpool dryer is working but not heating. I have checked the heating element, it's fine, the thermal fuse, it's good. I replaced one of the thermostats (the one that is next to the thermal fuse, not the element) and the other thermostat is fine. My dryer does still not heat. I do not understand this...
Posted on Jun 30, 2008
SOURCE: how to access heating element and thermostat on Admiral ade7000ayw dryer
The top has a hinge bracket in the back. pop the front up with a flat screw driver. you should see the heating element there and be able to access it from that point.
Posted on Aug 21, 2008
jsrock516
  • 5911 Answers
SOURCE: Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Posted on Nov 18, 2008
SOURCE: Dryer works but no hot air
did u get an answer i have the same problem
Posted on Oct 12, 2009
Continues to blow the high temp stat. I clean the blower and replaced the venting. I also replaced the heating coil the dryer heats up for a load and then it stopss heating. I test the high temp stat
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Feb 17, 2015 | Dryers
I have a frigidaire gallery series dryer that will run on low heat setting just fine but when I set it on medium or higher it shuts off after a minute or so. ..I replaced the thermistor but it didn't help....
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Nov 04, 2014 | Dryers
Our dryer shuts off completely when we dry several loads in a row. It restarts when we allow it to cool down. What is the problem?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings OR DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 30, 2014 | Dryers
Whirlpool dryer not running
If this a conventional dryer have you tried a temp switch located in the console panel
Jan 26, 2013 | Whirlpool Dryers
Heating element replaced. Worked one load and back or dryer seemed very hot. Turned off and later ran on low. Next load no heat.
Hi.
There is either a problem with the thermostats that turn off the heating element, or the heating element is plugged (elements has contact to ground and stays always on).
Heating element and thermostats are tested reading Ohms with a multimeter set at Rx1. If the circuit is open (Ohms stay infinite), then the part is defective.
If the machine overheated, then the element may be gone again. Test reading Ohms.
Also replace the thermostats (there should be two or three of them), unless the element had a contact, the most common cause for overheating is a shorted thermostat.
Aug 04, 2010 | EuroTech EDC158 Electric Dryer
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
i dont believe at this time its anything mentioned at top most people dont realize that dryers are split cuircuts
is this a 220 setup
and if its a 220
the cuircuit breaker for this is set by 110 each one for the heating element one 110 for the guages and motor
goto circuit breaker and flip the breakers this should return your dryer working ability
other thing is are the guages working properly
dryer doesnt have to run to test guages turn to the highest setting and let them run completly threw cycle if they stop on a particular setting for a long length of period then the guages are bad
May 29, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dryer does not get hot
pleas4e help my dryer is working but it won't get hot it just blows cold air please help me fix this problem
Jul 20, 2007 | LG DLE0332 Gas Dryer
Dryers Logo
Top Dryers Experts
