It only brings Direct ratio and it won't click on Widescreen en
My toshiba 40e210u lcd tv won't show full image on screen
The Aspect ratio of the TV could be on the wrong setting for the image you are trying to view. Widescreen's standard ratio is 16:9 ensure the TV is not set to zoom, 4:3, or pan & scan in the picture menu of your TV.
If the picture looks normal except it's just missing the edges or looks squashed or looks like it is zoomed in from the normal image then aspect ratio is probably the cause.
Aug 03, 2012 | Toshiba 40E210U 40 in. LCD TV
Does anyone know if the L37G10A supports PAL I as well as PAL B/G. I'm moving from Australia to UK and am wondering whether to bring the TV
Screen Type LCD Panel Type IPS-alpha Progressive Full-HD LCD Panel Panel Aspect Ratio 16:9 (Widescreen) Aspect Ratio Control Modes (TV/AV modes) 4:3, 14:9, 16:9, Just, Zoom1, Zoom2, Zoom3, DTV: 16:9 & 4:3 Full Aspect Ratio Control Modes (PC mode) 16:9, 4:3 Comb Filter Yes Progressive Scan Yes TV Tuner Receiving System DVB (Digital), PAL-B/G (Analogue) Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G
Contrast Ratio 1 - Dynamic: 20000 Picture Adjustment Modes / Film Modes Normal, Dynamic, Cinema, Eco Colour Temperature Control Cool, Standard, Warm
May 21, 2011 | Televison & Video
For software that I had I changed the screen to conventional ratio. My new software will let me go to widescreen. I lost track of my manual. How do I change back and forth?
Right click on desktop
Click properties or personalise
Click the monitor tab
Adjust settings.
You may need to click 'Advanced'
Jan 03, 2011 | Soyo DYLM24E6 Monitor
My 19" flat-screen monitor distorts pictures and makes everyone look fatter than they are.
It sounds like you did not set your PC video resolution to the correct aspect ratio, you should set it to the native resolution of this monitor to get the best pictures.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 24, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Width and height ratio
You need to set your PC video output resolution to the native resolution of this monitor, which is 1680X1050 @60Hz.
Right click on the desk top, the display properties will come up, click on setting tab, then you will see resolution setting choice.
Mar 28, 2010 | Acer AL2016W 20" LCD Monitor
The picture does not fit the screen. The top and bottom of the picture go beyond the screen
you may need to adjust the aspect ratio of the picture, there is typically an "aspect" button on the remote that will adjust the picture from widescreen, super widescreen 16:9 ratio and sometimes you can zoom in. try that
Sep 20, 2009 | Samsung Televison & Video
Lg 2242 won t display widescreen full resolution
the FX5200 doesn't support that resolution. You will need to buy a card that supports 1680 x 1050
http://support.dell.com/support/edocs/video/p57010/en/usage.htm#display_modes
Feb 05, 2009 | Star Computers & Internet
Widescreen tv=widescreen movie still have black on top & bottom
Sorry, you didn't provide enougb information for anyone to accurately answer your question. The most important thing you omiited was the nature of your video source. If anyone does answer this, I assure you it will be a wild guess. Here's my wild guess:
Your HDTV has a widescreen aspect ratio of 16:9. For every 16 units of width, there are 9 units of height. That ratio matches the exact ratio used in widescreen television broadcasting. However, most feature films (movies) on DVD have an aspect ratio of 2.35:1 or even wider than that. These films will display with horizontal black bars at the top and the bottom, so that you can see the full image. Unless you choose to use one of your TV or your DVD player's options to zoom or crop the image, the bars are 'correct' and there's nothing wrong.
Another possibility is that you have not configured your video source, such as a DVD player, to 'know' that you have a widescreen TV. Nearly all DVD players ship configured to output using a NON-widescreen aspect ratio, so you must adjust this setting using your player's setup menu. The same is true for most cable boxes and satellite receivers.
Finally, just because your TV is widescreen, the video source itself may not be. Most standard-definition broadcasts are NOT widescreen, for example.
If you re-post your question with adequate information about which video source exhibits this problem, I'm sure you will get much more specific and helpful answers.
Dec 30, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
Feb 29, 2008 | Philips DVP3020 DVD Player
How to Adjust the sceen ratio from 16:9 to 4:3
Since it's a widescreen monitor, the streching is likely from using a 4:3 ratio resolution on a 16:9 ratio monitor. Try setting the operating systems display resolution to 1440x900, since that's your monitor's native resolution (LCD monitors only really have one resolution). In Windows, resolution settings are found by right-clicking on the desktop, click properties, and go to the Settings tab.
Aug 05, 2007 | Philips 190CW7CS27 Monitor
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
