This site is more complicated to use than fixing the tv
How can I fix me tv
TV electronics are complicated and if you do not have a circuit diagram for your model TV or electronic training then you need an electronic TV repair man/shop to repair your TV.
Nov 30, 2012 | Protron Audio Players & Recorders
Have a 2 years old Akai PDP3273M1. Have checked for blown fuses and burned out components at the back. Need someone who knows Akai product or have repair manual to help.
Yes, you need to have service manual copy to repair this complicated tv. Below is an image of required service manual for this tv that can be downloaded from some sites for small fee.
Aug 08, 2010 | Televison & Video
Take a tv out of standby
You have a deflection problem. I would say the horizontal area is on the fritz! The H.O.T. is leaky or bad,along with two regulators and a capacitor or two. Please see a tech..this is a complicated fix!
Jan 10, 2010 | Sony KV-20M42 20" TV
We adjusted the brightness and the picture went
possibly the light bulb inside the TV is dead. Complicated fix, try to call a technician
Oct 21, 2009 | RCA D52W23 52" HDTV CRT TV
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
Smoke out of TV
My father used to have a saying, "All electronics run on smoke, you let the smoke out of them and they don't work anymore" Televisions are one of the most complicated devices ever invented by the hand of man. Modern sets seem simple due to the chips that perform very complicated functions. I would suggest finding a local repair technician that has access to the parts your set may now need and the test equipment required to track down some of the more difficult problems that occur in televisions.
May 17, 2008 | RCA F27669 TV
Colr red keeps coming in and out. had tv for 5 years and hasnt been serviced
If you don't have a degree on tv repair you should not try to fix it yourself, projection tv's are complicated on the way they are build, and when it comes to realigning the projector you are better of leaving it to the experts, dont try to fix it you might make it worst.
Feb 10, 2008 | Televison & Video
My ws 55805 yr. 2000
check this site first
if you dont have this in your set then
check convergance amp ic.
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
