Question about Bosch Washing Machines
Looking for a used control module for a bosch wfmc6400uc white front load washer. Washer works fine just can't read digital display window anymore. Any ideas suggestions out there?
    Top Expert:
  • Bosch Master
  • 74,896 Answers
Sorry we do not have parts.
Posted on May 03, 2017
  • 157 Answers
SOURCE: Washer will not spin
Carbon brushes in motor have worn down clean armture and replace brushes.
Posted on Dec 29, 2008
  • 245 Answers
SOURCE: Bosch Axxis Front load washer
a little bit of vanilla extract will take care of the smell. as far as getting the smell in the first place there is a problem with the drain system either the pump is not quite up to spec and leaving too much water in it or there is a problem with the line coming from it or the drains in your home. my advice would be to call bosch your washer is still under warranty and they will send someone out to look for it at no charge. this is not something i would be taking apart when the company will do it for you.
Posted on May 06, 2009
localwonder
  • 6784 Answers
SOURCE: clothes come out wet
HI, this is a common issue that is easily fixed by, replacing the control unit. this control manages the motor functions during operations. if this unit is not spinning correctly, replace the Control unit. aka(motor control unit). In you washer, they call the motor control board a (Control Unit). replace this asap if possible. this will fix your washer. ADDITIONAL CHECKS--(Make sure that this unit is also draining water properly as well. this will cuase wet spin outs as well).
Posted on Jun 10, 2009
Macmarkus
  • 2605 Answers
SOURCE: Bosch Nexxt Premium WFMC6400UC washer will not
Hi there, In reading your post I'm not sure I know how to approach giving a solution. Would it be possible for you to expand your post and perhaps provide more details ? Does the unit have 120vac going to it ? ( is there any lights in the display ) Does it fill with water ? ( with either hot or cold ) Do you hear the door lock ? ( you should hear a "click" when the lock engages ) Has there been any error code displayed at anytime recently ? As you can see just by saying the "washer will not wash or spin" leaves more questions rather than possible starting places to help move you toward a solution. I will watch for you to reply. Thank you for coming to fixya, I hope we/I can assist you further. Macmarkus :)
Posted on Mar 29, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have Bosch Nexxt Premium WFMC6400UC Front Load
Hello and welcome to fixya.
I`d suggest removing the back panel and inspecting if the belt has perhaps come off.
**Unplug the unit from the wall first**
If so, put the belt around the motor pulley and start it around the drum/drive pulley. As you hold it in place spin the large pulley and it should go back on, careful not to pinch your fingers...ouch :(
Let me know what you find out or if you require further assistance.
If this indeed solves the problem please take a second to rate my solution accordingly.
Thank you for choosing`"fixya" and good luck.
macmarkus :)
Posted on Jun 18, 2010
I n eed to find a scamatic for my washer
This video will show you how to change a door seal on this Bosch Nexxt Premium WFMC6400UC front loader washing machine
Jul 08, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
I USED GOO-GONE CHEMICAL ON FRONT PLASTIC WINDOW GLASS AND FOGGED UP THE SEE THROUGH WINDOW,IS THERE ANYTHING THAT CAN BE DONE. WHAT IS THE REPLACEMENT PART # ON THIS ITEM FOR A WASHER Bosch model...
Unfortunately, that part is not avail separately and the whole door assembly will have to be replace which is over £200. I think I'd live with the fogged door.
Sorry!
ps the door assembly is part no.241090
Jul 06, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
I need owners manual for bosch nexxt premium washer and dryer
Unable to read the display. The letters are no longer readable.
Jun 21, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch front load washer display says drainage blocked. What do i do?I already checked the exterior drainage hose
look for a front plate lower right corner / remove plate and inside is 3 in drain cleanout . ccw will remove and clean basket . cw to reinstall . should correct problem. mm
Dec 03, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Clothes come out wet
Jun 10, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Will not spin
I have an older model that would not spin. We did not have a digital display, so can't help there, but it turned out the bushes on the motor were worn out and needed replacing. Hope this helps.
Nov 26, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC does not start with the following status: Start/Paus light blinking Display says ready Pressing start does not do anything I have done the following: Holiding the Start...
A faulty module or timer/control panel. Unless you are getting some form of error code in the way of flashing lights or otherwise. In which case refer to manual. Good luck.
Sep 07, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Computer defunct
1. Try unplugging the washer power cord from the wall for 5 minutes and then plug it back in. See if this helps the problem. This will give the computer module an opportunity to reset itself. You may have to set the clock when you restart it.
2. This washer has a two year parts warranty. Find your original receipt and see if you are in warranty. If you are, find a Bosch warranty service provider here. I don't think Sears is Bosch authorized.
http://www.boschappliances.com/site_tools/Servicer_Locator1.aspx?menu_id=1&menulevel=02
There are several models of the Premium washer. This is the control panel that fits mine. Yours should be similar in cost.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1094534&PPStack=1
Jan 16, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
