Question about The Watches
How do I reset time on fitbit to correct time
The battery went dead and watch has wrong time
    Top Expert:
  • The Master
  • 76,846 Answers
Follow the link please for help Why is the time wrong on my tracker
Posted on May 03, 2017
Ware do I buy new replacement band for my Fitbit surge watch
you can replacement fitbit on fitbit store or watch store
Apr 12, 2017 | Watches
I didn't wear my Michele CSX 36 w/ diamond watch for a few days..When I went to put it on the time was wrong. So I tried to correct it and now it has not kept accurate time w/in a 24 hr period. Fo
I am pretty 100 percent sure that Michele CSX 36 diamonds only comes with a swiss quartz movement not an automatic movement.
So the problem seems to be that the battery is dying and need to be replaced. Stopping and going is usually a sign of a battery dying in a swiss quartz movement.
So it should be nothing major and just a battery.
Jan 23, 2012 | Michele CSX Diamond watch
I just replaced the battery on my Timex WR100 watch, but can't seem to reset it correctly. There is a sticker on the original battery "AFTER BATTERY INSERTION SHORT AC PAD AND BATTERY (+) TO...
It sounds like you're not far off. Peel the sticker back a little, and see if there is a small contact point (usually yellow metal) - this should be marked 'AC'. Short this to the + for 3 seconds, then repeat for good measure. If that doesn't sort it, try taking the battery out, wait about 30 seconds then put it back in and reset if necessary. If there's still no display, obtain a known working battery and try again.
If you still have no display, it's time to give up and admit it's dead.... unless you've been using a plastic coated paper clip.
Good luck.
May 19, 2017 | Timex Watches
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
My battery was dead, I had it replaced, but now the time is wrong and I don't know how to reset it.
mcdevito75 here, Best Bet is too return to the shop and have them re-set the time. Meanwhile from your home page type in the watches name.com and contact them (the maker) for an instruction manual.
Sep 26, 2010 | Watches
Alarm
You can press the four push buttons at same time to reset the watch and then set the time again, it will help you to solve the problem
Thanks
Tsai
Nov 05, 2007 | Freestyle Shark Buzz Wrist Watch
Error Code Display
Mine did the same thing after changing the battery and would reset intermittently without warning. For some unknown reason I decided to open the watch again. This time I reset the time and date with the back off the watch while deprssing the small spring that is there on the inside . Haven't had a problem since. Don't know if this is the solution but it worked for me. Good luck!
Les H.
Oct 30, 2007 | Timex Sports Ironman Triathlon 100-Lap...
Watches Logo
Top The Watches Experts
John mullen
D. E. Hev
 En Sukkert
En Sukkert
Level 1 Expert
Are you a The Watch Expert? Answer questions, earn points and help others
