Question about The Computers & Internet
Can I connect external speakers?
I can run the sound scale up to 40 or 50 and the sound does not get much louder. Can I use external speakers to get more sound?
    Top Expert:
  • The Master
  • 78,010 Answers
Yes on most computer you can use them and TV's as well.
Posted on May 03, 2017
4 Suggested Answers
  • 489 Answers
SOURCE: cant get any sound when connecting external speakers to dell d610
you are try to get sound for external sound. maybe you put the jack in wrong hole ? or your external device isnot working. or your volume is not high.
try these pls. and notice us.
Posted on May 29, 2009
  • 1584 Answers
SOURCE: IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Posted on Dec 22, 2009
  • 265 Answers
SOURCE: connecting external speakers
Hi ,
go into your settings on the tv and see if there is a section on speakers and try to set it to external speackers ,,,,,,,,,,,,,good luck Roy
Posted on Feb 18, 2012
Makes large thumping/chirping noise when turned on. Its not even connected to the receiver
Since you have said the speakers make this sound when "turned on", I'm going to assume there's some form of power amplifier attached (internal, external or otherwise). Based on the minimal information provided here, this simply sounds like the normal reaction of a speaker when the amplifier is turned on. In short, an audio speaker is a type of "transducer" and when power is applied (thru some form of amplifier), the cone reacts to the power surge and causes a thump, pop or other noise. Turn on your TV for example and you'll usually hear a small pop from the speakers...and a larger/more powerful amplifier is likely to make a louder noise. Without further information, in most cases this is quite normal.
Assuming there is an external power amplifier, my advice would be to turn the volume on the amp (regardless of whether there's a receiver connected) to 0 before turning the power on. If it still makes such a noise, it's possible the volume control of the amp may require cleaning.
Good Luck!
Apr 01, 2016 | Audio Players & Recorders
Not loud enough, is there anyway i can make it louder or do you guys have a website to buy parts?
We don't have any website here. CB radios typically do produce limited volume. If you have tried different external speakers already, and you are confident you have a good antenna setup, it seems you may need an amplifier. However consider all this first -
Jan 08, 2016 | Radio Communications
The sound is weak. The max. Volumn is very weak. How can I get it louder.
In general, tablets don't have powerful sound systems. Some ear-buds will play louder than others, but don't expect any built-in speaker to play loudly. Try different ear-buds, that may help, or an external "amplifier".
Dec 07, 2015 | Visual Land Prestige Pro 10D 16 GB Wi-Fi...
How do I make the volume from my speakers louder than my computer speakers?
depending on the auxiliary speakers you have, there needs to be a power source (either batteries, a power supply, or an ac cord); and the power needs to be turned on. Symptom sounds like you don't have the external power connected or turned on.
Dec 16, 2014 | Audio Players & Recorders
Cant get to play music without headphoes
Most modern computers come with internal speakers already installed, especially laptop computers.
These speakers may be sufficient if you are performing typical computer tasks, but when you play computer games, listen to music or watch movies on your computer, you may want louder and more vibrant sound.
You can achieve this by installing external speakers or headphones. These can be connected to your computer through the speaker or USB ports included on your computer.
Plug in the speakers or headphones.
If the speakers or headphones use a stereo plug, insert the plug into the speaker/headphone port normally located on the side or front of your computer.
This port is often color-coded green. If the equipment is connected using USB, locate a free USB port.
Some external speakers will also need to be plugged into a power outlet in the wall or your surge protector.
This may be all you need to do to get the speakers or headphones to work. If they do not, continue to the next step.
Open the audio settings on your computer.
From the Windows Start menu, open the Control Panel. Here you will find audio and sound settings.
Click the heading to see your sound and audio options.
Choose "Manage audio devices" in Windows 7.
Find your Playback device.
In the Playback tab, you can select your speakers and set them as the default for your system.
If you do not see your speakers or headphones, they have not been installed properly. Disconnect and reconnect them to see if it corrects the problem.
Configure your settings.
Select your device from the list and click "Configure" to test your settings.
You can adjust the volume by using the volume slider on your computer's task bar or using external controls on the speakers or headphones.
Install speakers
Aug 05, 2013 | Acer Computers & Internet
How to louder the mp3 file sound?
The laptop will not go any louder than the amplifier within it will drive.
If your volume is set to 100% then you may need an external set of amplified PC speakers. They work surprisingly well!
Dec 21, 2010 | Computers & Internet
How can I get a louder sound volume
some of the built in speakers of our PC and monitors are usually inferior when it comes to specs since they are just a add feature on the main gadgets. what i suggest is that you check for the Audio Line Out connection on your monitor and have it fed to a external sound blaster (no choice!).
Oct 06, 2009 | ASUS LCD Monitor
Brand new LC 42D65U
Sounds like your powerboard, take it back or call tech for replacement, dont settle for this, you paid good money for a working tv
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
19 inch LCD TV
Hi, Chances the Audio L/R are line level (can not drive speakers) other than they can either be output or inputs. If they are inputs, they are connected to a source such as a DVD player or if they are outputs, connects to an external amplifier where external speakers maybe connected. hope this be of some help/idea. Post should you need additional information. Good luck and kind regards.
Aug 25, 2007 | Westinghouse LTV-19W3 19 in. LCD...
No audio
The speakers of the Akai is good so it is tempting to open it louder hence the chance of damaging higher. Try this to find out if your speakers are damaged....... raise the volume if no sounds, 1. remove the cable connection of the speakers from the TV whilst still connected to the speakers. 2.use a 1.5v battery to bridge the free ends of the disconnected cables, if you can hear sound...scratchy sound then the speakers are not damaged then 3. Connect a new external speaker to the TV if still no sounds, post back a message
May 12, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Computers & Internet Logo
22 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
