Question about Electrical Supplies
Leroy Somer 20 kW portable generator with intermittent power engine runs great like flicker on and off at different times then go off
  • Mike Murray
    Mike Murray May 03, 2017
    A long time as long as I have a fan on the generator but without it just takes a few minutes to check the voltage at times it's worth supposed to be at 240 114 then other times 110 and then it comes right back to 240 112
    Top Expert:
  • 79,851 Answers
I would say the generator itself is defective or the voltage regulator is.
Posted on May 03, 2017
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
Having SDMO genset V250 volvo engine with Leroy Somer Alt 60 hz.Having problem that engine Shut Down with the message Min U Alt. Can anybody help me to solve this problem
Min U is minimum voltage output. If it occurs when under load, check load types and for shorts. If it happens during no load, check voltage regulator and exciter, and diodes
Aug 17, 2014 | Electrical Supplies
Generator will not run
Check the battery and make sure there is enough charge in it, check to make sure the contacts are clean and tight. if this does not help then more information is needed
Aug 13, 2014 | Briggs & Stratton Home Standby Generator...
Why do my clocks run fast when my Briggs & Stratton 15kw generator is running?
Electric clocks use synchronized motors that run on 60 Hz AC. The power company provides AC power with a precisely regulated frequency of 60 Hz. That means that the voltage jumps back and forth (positive to negative) 60 times per second. Your generator would do the same thing if it could run at precisely 3600 rpm (that's rev's per minute) - but it can't, because the engine is not that precisely controlled. In your case it tends to run (on average) a little fast. I hope you found this helpful. By the way, in Europe 50 Hz is the norm. If you run a clock designed for 50 Hz on 60 Hz power, it will run 20% too fast! Al K
Jun 20, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
What areall main causes of generator main stator burnt in sr4 &leroy somer alternators.
It can be many many factors, aside from the obvious (overloading) check the type of laods and the power factor of those loads, the gen alternator is rated at 0.8PF if your laod is a UPS without a switchable input filter, there is a good chance the unit is going into over excitation due to a leading PF. I have seen that before
Jan 07, 2011 | Caterpillar Electrical Supplies
Problem with a ef1000 generator running rough. starts easy, gets to operation rev range, lasts for 5 to 20 sec, then runs rough, changed oil, air filter and plug cleaned carby, made little differance run...
I purchased a Propane Generator from Central Maine Diesel a few years ago.
20 HP Honda engine, Italian generator head.
Paid about $2300 plus shipping via Paradise Freight which was a few hundred.
I see the price is just a bit higher now... But the one I want most is Yuchai which i saw from a website.
Recently it blew a capacitor. Central Maine sent me 2 for the price of one even though it is out of warranty. $39 total for two.
I looked at generators on island but a similar Honda at Quality electric was close to $6000 and it wasn't even a 13750kw. More like 8 or 9000kw if I remember right.....
They have many generators at great prices but this is the one I settled for.
However, it is said that the Cummins generator is more popular than others.
Cummins Generator Cummins Generator Set Supplier and Manufacturer in China
Nov 12, 2017 | Yamaha EF2400iS Portable Generator
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
Mar 16, 2010 | Pramac Electrical Supplies
Portable Generator doesnt generate any AC Current
is there a manual reset circuit breaker somewhere?
Dec 21, 2008 | Electronics - Others
Electrical Supplies Logo
41 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
