Question about Sewing Machines
Hi I have a Empisal em-250 deluxe and my needle is hitting the bobbin casing how can I fix this
    Top Expert:
  • Sewing Machines Master
  • 77,499 Answers
You need to have sewing machin3e repair shop check this problem, out may be it is out of time.
Posted on May 03, 2017
When I select zigzag, the needle moves to the right, but when I sew, the needle stays in the right position but sews straight.
It has probably stuck even though never used and stored in the original box. You may want to have a sewing machine technician look at it.
Dec 04, 2017 | Sewing Machines
Hi there. Empisal EM-250 Deluxe Sewing Machine, I'm realy battling to get the tension, top and bottom, and the material doesn't want to go thru by itself. PLEASE can you help?? Regards, Adri
If the fabric will not feed through it suggests that the feed dogs have possibly been left down.
Getting tension right is really a matter of trial and error. Work through them starting with lowest number on the upper first leaving the lower tension alone. If you need to change the lower tension, do it by very slight turns of the bobbin screw and note carefully which way you turn it and by how much as there are no numbers to follow.
You might check that there is no lint trapped in the tension discs before starting as this can cause problems. Run a thick thread through them to clean.
Jun 25, 2015 | Sewing Machines
Empisal sewing machine EM-250 DELUXE
you can check on ebay to see if they have any and what they are selling for or call a sewing machine shop and see if they can help you.
Dec 10, 2013 | Sewing Machines
Need to replace Thread Tension Dial on my Empisal EM 250 DeLuxe Sewing Machine. Please help
Poppie, are you still stuck? I have a vintage Empisal and did the same thing - but I finally figured out how to put the tension back together. Check out my blog to see if you have a similar machine and I may be able to help.
makingmakesmylife.blogspot.co.nz
kind regards
KC
Jun 28, 2012 | Sewing Machines
Needle hits the bobbin casing.
check to see the bobbin is in correctly first, is the needle in the centre?
Nov 23, 2009 | Sewing Machines
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
