Question about Electrical Supplies
20kw Leroy Summers generator intermittent power output
4 Suggested Answers
  • 6468 Answers
SOURCE: have a generac generator 20kw air coolded, automatic standy model 60511 that the battery goes dead all the time
how old is the battery? charge the battery then remove the negative cable place a test light between the battery and cable if the light is on you have a draw unplug things til the light goes out thats your draw
Posted on Oct 08, 2012
traviskelly8
  • 62 Answers
SOURCE: why want a 20kw generac guardian home generator not switch back to utlity power ?
Contacts are burnt
Posted on Jun 03, 2014
emissionwiz
  • 80378 Answers
SOURCE: Leroy Somer 20 kW portable generator with intermittent power engine runs great like flicker on and off at different times then go off
I would say the generator itself is defective or the voltage regulator is.
Posted on May 03, 2017
Where is the speed sensor located on a 20resa kohler genset
Kohler Generator issue 20 RES - YouTube
? 0:24
www.youtube.com/watch?v=CT9u64dZna0
Apr 28, 2012 - Uploaded by Jeremy vanEyk
Brand new Kohler Generator Test cycle issue. ... Oh, and Mike, good call on the carb--that happens on some 20RES models. ...Indicates Locked Rotor (Lr). ... I'm on my second 20 RES-L,home depot swapped out the 1st one. ... Kohler 20KW RESA Whole House Standby Electrical Generator - Duration: ...
May 19, 2015 | Kohler 20resa 20kw Home Emergency Backup...
Having SDMO genset V250 volvo engine with Leroy Somer Alt 60 hz.Having problem that engine Shut Down with the message Min U Alt. Can anybody help me to solve this problem
Min U is minimum voltage output. If it occurs when under load, check load types and for shorts. If it happens during no load, check voltage regulator and exciter, and diodes
Aug 17, 2014 | Electrical Supplies
What size generator do you need to run 19100 watts
if you're talking RESISTIVE (like incandescent light bulbs and radiant electric heaters), then you need about a 20KW generator. If you're talking REACTIVE (like electric motors and fluorescent lights), then you need a 40KW to 100KW generator - higher if you're starting all the motors at once, lower if you're stage-starting the motors. If you're talking about a mix of resistive and reactive loads, then you'll need something between 20KW and 100KW depending upon the mix.
If you're talking about MAXIMUM 19100W but realistically only a small part of that load is actually likely to be required at any given moment, then you can use a much smaller generator. For example, my own house has a 100A 240V breaker panel, for a total capacity of 24KW. I can realistically run what I REQUIRE from a 3.5KW generator, though, by intelligent load switching.
Jul 12, 2014 | Electrical Supplies
Have air cooled 20kw generac cranks but does not start
THERE SHOULD BE A LOW OIL SENSOR ONTHE SIDE OF THE MOTOR PLEASE MAY CAUSE THE MOTOR NOT TO START YOU SHOULD BEABLE TO JUMPER THE TWO WIRES ON THE SENSOR AND SEE IF THE GENERATOR WILL START
Apr 07, 2013 | Generac Guardian 20kW Model : 5875
Kohler 20kw RESA "invalid shutdown" fault
I have a Kohler 14Res and an error Invald Shutdown is indication and the engine is not crancking
Jan 30, 2013 | Kohler 20resa 20kw Home Emergency Backup...
Have a generac generator 20kw air coolded, automatic standy model 60511 that the battery goes dead all the time
Oct 06, 2012 | Generac Electrical Supplies
Battery does not stay charged on my 20kw generac generator
WAS A 110 VOLT CIRCUIT RAN TO IT FROM THE NORMAL UTILITY POWER OF HOME OR BUILDING IT FEEDS?
NORMALLY THIS IS DONE IN A SEPERATE CONDUIT FOR CONTROL WIRES.AND THE FEEDERS ARE IN ANOTHER CONDUIT.
WITH A DIGITAL TEST METER,CHECK FOR 120 VOLTS AT THE BATTERY CHARGER IN THE GENERATOR CABINET.USUALLY THERE IS A RECEPTICAL TO PLUG THE CHARGER INTO.
IF VOLTAGE IS PRESENT AT THE BATTERY CHARGER AND INDICATOR LIGHTS ARE ON, CHANGE METER TO DC AND CHECK FOR 13.8 VOLTS OUTPUT FROM THE BATTERY CHARGER.IF YOU HAVE OUTPUT VOLTAGE TO THE BATTERY,AND IT IS DEAD,CHANGE THE BATTERY..
HOPE THIS HELPS YOU,BEST OF LUCK.....
Nov 01, 2010 | Generac Guardian Model 5784 20 Kw...
Powermate 5000
20kw means 20 KILOwatts (kilo=1000), so 20kw=20,000 watts
So the Powermate 5000 refers to wattage. 5000=5kw
Sep 04, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
