Question about Brother Sewing Machines
Putting needle holder by on brother sewing machine xl 5030
  • Brother Master
  • 646 Answers
The needle clamp pin is inserted before the screw is inserted. This allows pressure to be made on the needle.
The needle holder is held on by a screw. See the diagram that I've sent an answer to.
Posted on May 04, 2017
How to put back the part where the needle is attached?
youtube has good videos. Check this link, you will probably be able to see how the part is attached. Brother XL 6562 YouTube
Jul 31, 2014 | Brother XL-6562 Mechanical Sewing Machine
HI I HAVE A BROTHER XL-5011, the clamp that holds needle in place fell off whilst sewing now it won;t stay on thnxs
needs a new needle clamp screw & possibly the needle clamp too
Jan 11, 2011 | Brother Sewing Machines
Needle falls out of holder
Are you inserting the needle flat side facing the rear of the machine? Use a coin to tighten and loosen the screw. If, that doesn't work call Brother at 1-877-276-8437 and ask for a replacement screw because that one may be stripped. Good luck.
Oct 04, 2010 | Brother XL-5340 Mechanical Sewing Machine
Brother xl 2230 - cannot fill spool as holder does
Check the bobbin winder rubber......remove the top cover and take a look. Remove worn rubber and use as a sample when you go to the Brother Store....also have your model number handy. If you cannot access easily, phone Brother store and ask for a quote to replace.....if it is any more serious they should confirm with you prior to doing additional work.
Sep 05, 2009 | Brother LS-2125 Mechanical Sewing Machine
The needle holder came off the pin that holds the sewing foot in place. It appears a part is broken
Not familiar with the XL-5340 but I have an XL-6562 - mine has done the same thing. There is a small black screw that requires an allen wrench to adjust. It is on the right hand side of the needle holder. Apparently it just works loose over time and with use. My son put the holder back on, adjusted that screw with an allen wrench and it has been fine. Not sure what to tell you though about the missing thread guide. Maybe it will be ok without that - I guess try it and see.
Aug 05, 2008 | Brother XL-5340 Mechanical Sewing Machine
Bobbin holder turns and keeps bending needles
the whole upper assembly may have come out of alignment when the machine bent the needle, the upper cover may have to come off, and study the inner metal area where the needle is attached for alignment bolts or screws, maybe one has come loose. On ours if you choose the zig zag and adjust it all the way out it will do that everytime. maybe download the user manual at and see if theres something in there also.
Jul 23, 2008 | Brother XL-2230 Mechanical Sewing Machine
Needle holder assembly came off
If you look carefully you should see a small allen head screw on the needle clamp assembly. There should be a J shaped part which goes into a hole on the bottom of the assembly. Reassemble everything,put the assembly back on the needle bar and tighten the screw with an allen wrench.
May 21, 2008 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
