Question about Building Materials
Garage door opener lite flashs and unit makes clicking noise
    Top Expert:
  • 12,962 Answers
If this is happening during the close cycle it is because something is in the ways of the door sensors and preventing the door from closing. When this happens the light flashes and you hear this background clicking till you resolve the issue. Or check the wires to sensors - if disconnected ,same thing happens.
Posted on May 03, 2017
I have a Chamberlane Lift Master Professional I went to open it yesterday and it would not open. When the button is pushed the unit just clicks and the controller light is blinking 5 times then pauses and...
The code it is flashing is "RPM sensor or motor overload." It is not a door sensor problem. The RPM sensor is a small circuit board just in front of the motor.
Mar 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener makes a clicking sound when activated by the remote or wall unit and the lighton the back of the opener flashes. craftsman.
If the opener is making a clicking sound when it is running the chain is too tight. Post back with the number of flashes from the light.
Dec 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain LiftMaster Residential Garage Door Opener Chain Drive 2255. It no longer opens or closes. When you hit the button it makes a churning noise then stops. There is a code flashing on...
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and is probably stripped. The part number is 41A2817.
Sep 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO don't not respond other than a click noise when remote or wall unit is pressed. When power is removed, then restored, wall switch is pressed, unit clicks, then green LED on back of unit...
The unit is flashing the code for 'motor overheated or RPM sensor failure'. If the door is stuck in the open position it could be because the trolley is jammed against the bolt just in front of the motor unit. Remove the bolt and run the opener until the door is closed. Now on the side of the motor unit you will find the 'up limit' adjustment. Turn this 2 full turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Dec 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Grage door blinking yellow, click and won't open with anything.
TRY RESETTING THE UNIT BY UNPLUGGING IT FOR ABOUT 5 MIN.
IF WHEN YOU PLUG IT IN THE REMOTES STILL DON'T WORK TRY TO REPROGRAM THEM.
IF STILL HAVING TROUBLE--
COUNT THE FLASHES - GOTO LIFTMASTER.COM DOWNLOAD A FREE PDF FOR A SIMILAR UNIT (THE MODEL NUMBERS ARE DIFFERENT BUT THE CODES ARE THE SAME).
HOPE THIS HELPS
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Not working
clicking noise usually is from relays on logic board. you over-heated unit. wait 25 monutes for motor to cool.
Aug 02, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Building Materials Logo
57 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
