Question about RCA Televison & Video
Are there any rf modulators with rca in and STEREO coax out? Looking for $20-30, not $800-1000. Thanks.
    Top Expert:
  • RCA Master
  • 12,962 Answers
Check it out on ebay - they have just about every possible unit/adapter.
Posted on May 03, 2017
Testimonial: "I've done that. And looked at other sites. The problem is most don't mention output specs. I did see one from Radio Shack that stated that even with rca stereo in, coax output is mono. That's why, before buying everything out there and being disappointed, I thought I'd ask. Thanks for the reply, though."
How do I hook my old PS2 to my RCA TV with my converter box?
RF cable coax out to TV from the RF Modulator .....RCA jacks "red-yellow-white from ps2 to RF modulator "its not called a converter box"//lol Put the TV on channel 3 you should see the ps2 screen. Same way you would hook up a DVD player to a CRT TV..heres a video
TVs DVD Players How to Connect TV DVD Player VCR With Modulator
Mar 22, 2015 | RCA Televison & Video
I have a cable TV connection, analogue, no hdmi, how do i connect dvd player and my other speakers to the TV?
You could purchase an "RF Modulator" box (a very small electronic box) which is designed for connecting DVD players to TVs which have only a coax cable input. The 'RF Modulator' box needs to also have the external audio connections ('RCA plugs) for diverting the audio signal to your external amplification (other stereo & speakers). These RF Modulators are found at most stores, and run $16 - $25.
Feb 05, 2011 | Philips Televison & Video
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
How to connect to cable box and TV using only coax cables
If I understand you correctly you do not have the RCA inputs on the TV and need to hook up this DVD with a coax cable.
What you will need to get is a RF modulator with both coax and RCA inputs. This will allow you to connect the Cable box up to the modulator with the coax line as normal and then the DVD with the RCA cable to the modulator and then the modulator will connect to the TV with a coax giving you access to both. Here is an example of the type of Modulator you will need.
MODULATOR
Good Luck....
Jan 14, 2010 | Jwin JD-VD502 DVD Player
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
Connect magnavox dvd to ge tv HELP!
You need to go get an RF modulator. They can be purchased at Radio Shack or a number of other electronic shoppes for a reasonable price.
The RF modulator connects to the coax cable connector and it has inputs for the RCA connectors.
Cheers ... Best wishes
Jan 30, 2009 | Televison & Video
Coax that looks like RCA?
There is a distinct difference between coax and phono (rca) cabling. Coax, sometimes called RF, is a cable that carries audio and video at the same time, what we call a "modulated" signal. RF connections look as if they are threaded on the chassis of your TV or VCR etc. A lone "Phono" cable moves either audio or video, but not both at the same time, unlike coax.
If you are attempting to patch RF, your cable must be coax at both ends.  Hope that helps.
Jan 07, 2009 | Apex Digital AT2014DV 20 in. TV/DVD Combo
Installing DVD player/RF Modulator with Star Choice
The RF modulator probably had a red, white, yellow trio of RCA jacks (A/V jacks), a coax jack marked "antenna" and another coax jack marked "TV"
Putting the DVD output to the A/V jacks allowed it to play out to the TV, which couldn't otherwise accept the DVD player.
The satellite box probably has coax and a/v jacks as output. Use the coax as output to the antenna input of the RF modulator, and the A/V jacks of the DVD player to the A/V jacks of the RF modulator. Hopefully the modulator allows the A/V jacks to have priority over the coax input, so that when the DVD plays it "wins"
Jan 12, 2008 | Televison & Video
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
RF Modulator
The RF modulator changes the outputs from RCA (red, white, and yellow) to a Coaxial Cable (COAX).
You connect the DVD players RCA outputs to the RCA Inputs on the RF Modulator, then connect the COAX Output from the RF Modulator to the television.
Best of Luck.
Oct 23, 2007 | Car Audio & Video
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
