Question about Uniden Lands Phones
CAN NOT CLEAR WATER PROOF DECT 6.0 PHONE TO REGISTER IT SAYS TO PUT ON BASE BUT I WANT TO REGISTER ON MY OTHER UNIDEN BASE BUT PHONE WON'T FIT ON BASE
    Habit-Forming:
    New Friend:
  • 17 Answers
Not stating the model number of your phone makes it a bit difficult because the process is not the same on all models. I am going to deal with the cordless main base only Remove any handset from the main base cradle. Then
On the waterproof handset Press and Hold the # sign until the Registering handset option shows then release it.Then on the main base, Press and Hold the FIND hs or Find or locator button for 5 seconds ( if there is no IN USE light on the base) or until the IN USE light come on, then release it. Hold the handset near the base and it will register.
Please note the Uniden waterproof handset could be a bit tricky to register and not knowing the model makes it more difficult. and you may have to apply other methods.
Posted on May 04, 2017
How do I find messages/mute?
To hear your messages, press PLAY on the base.
To mute, press CLEAR on the base.
See pages 22 and 6 of the manual: Owners Manual User Guide for Uniden Dect2188 3 Dect 6 0 Cord cordless...
Feb 22, 2015 | Uniden Dect2188-3 Dect 6.0 Cord/cordless...
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
Reconnect handset to base
Since you didn't specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download the manual. Follow the instructions to register the handset to the base.
Mar 01, 2013 | Uniden DECT 6.0 Cordless Phone ID
Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
Mar 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
How to register phones?
Reset Procedure for Cordless Phones
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Mar 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
Search inside Uniden DECT 6.0 Cordless Telephone Expansion Handset with Caller ID Knowledgebase the water proof phone base holder jack has yellow tab in bottom and doesn't fit in hole ...is the yellow tab...
I finally realized the ac connections came in 3 sizes ...the first 2 I tried didn't fit the waterproof phone; altho 1 came in the same box.....I feel a little humble
Jul 20, 2008 | Uniden DECT 6.0 Cordless Telephone...
Lands Phones Logo
29 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
