Question about Pool & Spa
My 3 wheeler fell in salt water now it will not start can you bhelp me
OAKLEY ROKR fell in water- will not turn on- can anyone repair ? Lozomex are you available
If it was fresh water then it could most likely be saved but due to it being salt water unfortunately it will not be possible as the salt is very corrosive and will have done damage to the electronics.
Mar 06, 2012 | Oakley O Rokr Pro Sunglasses
My Sony Camera fell in the sea water, can it still be fix? How?
Salt water damage is very bad for electronic devices, especially if the device was switched on at the time when it was dropped into salt water.
The cost of repair if you can get someone to repair it would most like be very expensive.
I would recommend you purchase a new camers, it most likely be a later and better model.
Dec 19, 2011 | Sony Cameras
Pump goes into sleep mode because of low salt light. I have added 240 pounds of salt since the light came on and fell that I may be haveing other problems. Would it be normal to have to add that much salt...
No more salt for now!!!!! 1st thing you need to do is check your salt ppm.. must be around 3000ppm.. The 8110 models have issues with their cells that will continue to give you a low salt reading regardless of the salt level.. You must check the cell for calcium build up and clean.. You can soak with vinegar or as others recommend, muriatic acid to clean the cells. Pressure flush to get all the "White Flaky" stuff out.. Dirty cells WILL give you a low salt error on the unit.. If after cleaning the cells you still get this code, you may have a bad cell.. If you are just starting out and the unit is new, YES you will probably add over 300 lbs of salt to get you going and be around 3000ppm on a 14000 gallon pool... Be sure to run your pump only for 24 hrs to properly dissolve the salt and then set your cycle...
Hope this helps...
Sep 08, 2011 | Intex Automatic Salt Water System for ...
The filter wasn't changed for a couple of weeks and lots of leaves fell in our pool, I changed the filter put more salt but the pool water is getting greener and greener every day, what can I do? Intex...
Shock your pool ... take it to about 20 ppm and run the filter 24 hours a day. Brush the sides. When the pressure goes up 10 lbs over fresh start pressure, backwash or clean your cart as appropriate. Is your salt cell calling for more salt? Salt is persistent in the water (like CAL, salt doesn't just go away. The only way you loose either is by splash out and/or backwash.) If you dont know the level and your cell will not tell you, get tghe level checked at your pool place. You should have around 3200 ppm salt. Dont expect your salt system to keep up with the green stuff when the green stuff is established. You MUST use dry or liquid CL to overcome. You MUST brush the pool sides and bottom. You must run the filter 24 hours.
Between the green stuff and the sun, the CL your cell is making is consumed almost as fast as you make it.
Get your Cyanuric acid level to 80 ppm.
I hope this helps you ... Thanks for your interest in
Jul 31, 2010 | Intex Krystal Clear Model 635 Pool Filter...
How can I get my LG VU messages from the cell phone once it fell in salt water?
Once the phone falls in water, it will be able to work again all you have to do is to open it up and dry it.
But once the phone falls into salt water, the panel of the phone is totally gone and beyond repair.
The only messages you can get are those that are on your sim.
Take care
Jun 21, 2010 | LG Vu CU920 Cellular Phone
Fell in salt water, dryed it for 3 days, is displaying "battery is required... powering off" when the battery is in. ALSO " Repair mode, please remove the battery to reboot your phone. Is it a write off?
the fact that it fell in salt water is proberly affecting it, try rincing it in pure clean water and then let it dry out, that might help. water shouldn't affect the phone, but the sault would.
Aug 02, 2009 | Cell Phones
My samsung SGHJ700 fell in water.iwhat should i do?
The following method can be tried when everything else failed and the phone went through the washing machine, fell in salt water or was in dirty water for a long time etc.
Remove as many parts as possible (Sim card, covers, battery)
1. Soak the phone as soon as possible in distilled water to dissolve any dirt, salt, soap etc ( an ultasonic cleaner will be helpful )
2. Repeat step 1 if necessary ( depends how dirty the water was )
3. Soak the phone in Iso Propyl Alcohol ( a very short time in an ultasonic cleaner will be helpful to dissolve the distilled water in the alcohol )
4. Let the phone dry thoroughly,
5. Cross your fingers and switch it on.
May 17, 2009 | Samsung J700 Cellular Phone
My camera fell into sea and now some of the features are not working.model DMC-FZ8
Unfortunately salt water causes all the electronic terminals and wboards to oxidize. Just getting plain water in. would work after it dried completely, but salt water , not good. You may be looking for a new one. Sorry
Dec 19, 2008 | Panasonic Cameras
N70 Fell in water, Only White Screen is Shown
Don't put the battery / power on. Take the phone to the mechanic / nokia service center on urgent basis. They will remove the remnents of the water and salt over the circuit.
If the problem is still not solved, either the power supply or the motherbaord will require a replacement.
Dec 16, 2008 | Nokia N70 Cellular Phone
Fell in sea / wont turn on
would you like the bad news or worse news first? salt water begins to corrode almost instantly (bad news) time to buy someone a new cam (worse news) sorry
Jun 07, 2006 | Casio Exilim EX-S1 Digital Camera
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
