Drivers to down laod.
I just bought a new cell in Japan Kyushyu area. but when i tried to connect my USB to my Acer PC it told me that because my system is English it cant read the instulation. what can i do ?
How can I unlock my phone
- Unlock all Sony Xperia 2010 Year (under test, private only)
- Unlock all Sony Xperia 2011 Year( with Test Point) (under test, private only)
- Flash All Sony Xperia/ Sony Mobile Android based mobile phones
- First in the World: Read Trim Area from Running OS via ADB( Android Debug Brigde, ADB - included)
- First in the World: Write Trim Area from Running OS via ADB (Android Debug Bridge, ADB - included)*
- Trim Area Backup Read using ADB/BootLoader(for test or Security reason)*
- Trim Area Backup Write using ADB/Bootloader**
- Single Trim Area element Read/Write*
* Not all TA elements can be written or read and not all Platforms support it.
** Not all TA elements can be written or read.
!!!Software require Internet Connection for all operations!!!
download tool
http://www.mediafire.com/download.php?7gede2no6nsccvd
Usage:
!!!IMPORTANT!!! Before any operation with any new phone - Back it UP! Later
you can restore it if somethings gone wrong.
A) To read/write Trim Area
using ADB:
1. Connect your phone to PC using USB Cable.
2. Enable USB-Debugging in Settings->Development menu
3. Install drivers
4. Go to TA work tab, click ADB in the software and press Connect.
If you need to Cancel you can click cancel to stop operation
5. Wait software to check root in your phone and try to root it.
6. If your phone is not rooted you recieve a message how to root
your phone.
7. Click Backup TA. All your TA will be backed up and saved in new
folder, same as your imei number
8. If you need to restore phone - click Write TA from Backup
9. If you need to read/write single element: enter element number in
heximal (for example 7da) and press read/write
9a. Upon write operation you will be asked to open the file to
write, so please be ready for this file to open.
using BootLoader:
1. Training: Connect phone in Flash mode (Hold the back (or the
Volume down in new 2012+ phones)) key and connect the USB cable.
2. Install drivers (x64 or x86)
3. Check if driver install ok
4. Disconnect phone
5. Go to TA Work tab and click Bootloader
6. Click Connect button. If you need to cancel you can click cancel
to stop operation
7. Connect phone in Flash mode (Hold the back (or the Volume down in
8. After successfull connect Click Backup TA (for your security)
9. If you need to restore click Write TA from Backup
10. If you need to read/write single element: enter element number
in heximal (for example 7da) and press read/write
10a. Upon write operation you will be asked to open the file to
B) To flash a S1_Boot android phone
1. Go to Flasher tab
2. Follow the procedure 1 of the read/write TA using BootLoader
(Traning)
3. Click Open firmware (acceptable formats: zipped firmware bundle,
with loader.sin inside), file format - zip or 7z (7-zip)
4. Select files to flash(eg. 1 file or All files)
5. Connect phone in Flash mode (Hold the back (or the Volume down in
6. Install Drivers (x64 or x86 - according your system OS)
7. Stand by, software detect phone and send the loader.sin from the
archive
8. Click Flash when phone is connected and software hint says "You
can press the Flash button now"
8a. Keep in mind, the system.sin takes longer at 99%, this is ok,
need wait.
C) To unlock phone
without Test Point (2010 phones only):
2. Install Drivers (x64 or x86 - according your system OS)
4. Disconnect phone
5. Enter your user id and password
6. Click unlock
8. Follow the on screen instructions (some phones require one or two
reboot).
with Test Point:
4. Disconnect phone
5. Connect the Test Point.
7. Keep the Test Point connected
8. Click Unlock
9. Stand by.
9a. Longer in description faster in process about 20 seconds.
Apr 19, 2016 | Sony Ericsson XPERIA X10 Cell Phone
Magicjack how to connect majic jack on acer chrome book
connect it in your usb and let it install drivers and then you have to pick up a password. Phone number is provided automatically. You just need to pick up your area.
Dec 24, 2013 | Acer C7 Chromebook
Ethernet controller down laod free
here's the link to the downloads section of the acer website:http://us.acer.com/ac/en/US/content/drivers
i need the model # of the laptop to be more specific:)
Jul 29, 2011 | Acer Computers & Internet
TMC program does not see Symbol mc9090. I've done this a dozen times on my old PC and it has always worked. I got a new PC, down laoded all the programs that were on the old PC (I think) but cannot connect...
When the PC looks for a driver, select the option to choose a location. When prompted for a location, point it to the following folder:
C:\Program Files\Symbol\TCM2\USB Driver
This is the default location after installing the Device Configuration Package (DCP).
Apr 07, 2010 | Symbol MC9090-G RFID Handheld Barcode...
Hello, I'm afraid that i'm going to sound ridiculously stupid. but i've just been told that in order to use my acer aspire one p531h obk for work that i need to use a softfone and a usb or blue tooth...
Yes it should be fine. That laptop looks to use a N270 processor so no problems with trying to get 64bit drivers. Laptop has a builtin soundcard and supports USB and Bluetooth.
Any new good USB or Bluetooth headset will come with drivers for XP, Vista and Windows 7 32bit. Vista drivers should work with Windows 7 if non are availble yet, but you will need to try 'em. I'm assuming you are not running Linux tho...
Jan 18, 2010 | Acer Aspire One PC Notebook
Cannot connect Samsung GT-S5230 tp PC
TRY TO CHECK THE SETTING OF YOUR PHONE REGARDING CONECTIVITY.
Aug 21, 2009 | Samsung U900 Soul Cellular Phone
XP INSTALLING
The drivers can be obtained from this website.
If you haven't dumped the OS, use DriverMax to backup your drivers to a USB stick and restore them under XP.
If you have a second computer and are feeling adventurous, you can use the drivers, your XP disk and a program called nLite to create a custom XP disk with the drivers built in. You can also load Service Packs in case your disk is out of date.
Dec 15, 2008 | Acer Aspire 4720 Notebook
Usb problems
This might because your USB controller is disabled in BIOS try enabling it
Nov 21, 2007 | Acer Aspire 5100 Notebook
Wireless keyboard and mouse acer
Check Cell should be inside the keyboard and mouse  , keyboard and mouse should b in line of sight .check in device manger whether drivers are properly installed or not
Gizmo1
Oct 22, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
David Payne
David Payne
