Question about Kenmore Refrigerators
Light in kenmore refer burned out replacement bulb won't lihgt
This Kenmore refrigerator is about 8 years old. The light fixture in the top of the fridge compartment has two light bubs. One burned out about 6 months ago. We bought 2 exact replacement bulbs (expensive) But neither worked. Now the second bulb is out. Same problem, new bulbs don't light when screwed into the socket. Is something tying to protect us from ... what?
  • 410 Answers
SOURCE: Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
  • 139 Answers
SOURCE: Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Posted on Jan 27, 2008
  • 247 Answers
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
Posted on Apr 05, 2008
  • 1462 Answers
SOURCE: Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Posted on Dec 01, 2008
Lights in my kenmore refrigerator, freezer on bottom, burned out. I purchased two 60w bulbs and replaced them. I plugged in the refrigerator and the lights were on. Then a couple of minutes later,
Hello Sharon;
My name is Peter. I am a retired field service refrigeration technician.
You can not put normal house hold appliance bulbs in appliances. There are special bulbs for refrigerators, clothes dryers and close washers.
The bulbs are usually available in the local market and marked; "Refrigerator" and Freezer".
You may have a bad door switch. But, I am more prone to go with the wrong service bulb.
Your Friend,
Peter, Baltimore, Maryland, USA
Nov 16, 2014 | Kenmore Refrigerators
Kenmore sidexside light burned out. replaced bulb, won't light.
There is a plastic switch that works the light in the door jam. Unplugg the fridge before popping this plastic switch out. I would order one first but if your light fixture is in good shape and not burn on the inside and the wires look good it is most likely the door switch. The door switch is just like an on off switch for any light its just spring loaded to turn on when the door opens. good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a kenmore side by side. Are there 2 lights in the freezer? It is dark on the bottom, are there 2 bulbs?
Usually there is only one light in the freezer section. Make sure food is not pressed against the light fixture blocking the light.
May 14, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Dec 01, 2008 | Refrigerators
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
