Question about Watches
Why does my geochron stop advanceing after approx. 2 hours?
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 | Watches
Tip
TGHK watch instructions
This is not for Tag Heuer, it's for TGHK watches.Here's the procedure: Press the MODE switch to step through the modes until you see the seconds blinking (righter after the ALARM set mode). Press the RESET switch to advance to the function you want to change (e.g. hours). Press the START switch to increment the hour to the correct time. Press the RESET switch to advance to minutes and, again, increment the setting using the START switch. (Hold the switch down to advance the numbers rapidly.) When you have stepped through all the elements and have everything as you want it, press the MODE switch once to return to normal time display. To set the ALARM: Press the MODE switch to display the alarm function. Press RESET once to see the hours blinking. Press the START/STOP switch to advance to the desired hour. Press RESET to advance to the minutes and set the minutes using the START/STOP switch. Press the RE#SET switch. The time will stop blinking. Set the alarm sound for either ALARM or CHIME using the START/STOP switch. Press MODE to return to the time display. To turn the ALARM off: Press the MODE switch to advance to the alarm mode. Next to the AL indicator there will be either a small ALM or CHI displayed. Press the START/STOP switch until they both are off. Press MODE to return to the time display.
on Mar 18, 2010 | Watches
How to set clock
THE WATCH IS SET OUT AS TOP LEFT BUTTON = B
BOTTOM LEFT BUTTON = A
TOP RIGHT BUTTON = C
BOTTOM RIGHT BUTTON = D
10 Half Digit Digital FL145, FL186
Normal Time Display
1. Press A to change mode.
2. Press B for EL.
3. Press C to toggle 12/24 hour format.
4. Press D to stop alarm sound.
Time/Calendar Setting
1. From normal time display, press A three times to enter setting mode. Seconds will begin flashing.
2. Press C to reset seconds to zero.
3. Press D to set and advance to next setting value.
4. Press C to increase digit; press and hold C for fast advance. Press D to set each setting value.
5. Setting sequence is: seconds, hour, minutes, month, date, day of week.
6. Press A to exit setting mode.
Alarm Setting
1. Press A to change to alarm mode (AL).
2. Press and hold C for alarm sound testing.
3. Press C to toggle alarm/chime on/off.
4. Press D to enter setting mode; hour will begin flashing.
5. Press C to advance digit; press and hold C for fast advance.
6. Press D to set hour and minutes.
7. Setting will automatically exit setting mode mode after minutes are set.
Chronograph Mode
1. Press A to change to chronograph mode (ST).
2. Press C to start/stop chronograph.
3. Press D to reset chronograph when it is not running.
Split Time
1. Press D while the chronograph is running.
2. Press D again to return to the chronograph.
3. Press C to finalize timing.
4. Press D to reset to zero.
Mar 29, 2012 | Fossil Fuel Josh JR9120 Watch
Can't set time on aqualite watch-field ranger
I have an aqualite field ranger watch too. I lost the information but I found another notice for another watch and I was able to set the TIME as well as the alarm. I am not despairing as to one day set the date correctly! ;-)
The instructions I found are for "LIFELONG Chrono Alarm Sport watch" from Hanig & Company. The watch this particular instructions comes from has a rectangle LCD display that only takes the center of the dial, and only 3 buttons for the functions.
Aqualite has 4 buttons, but one of them is only for lighting the dial only, therefore if we use the 3 other buttons the same way they are described in this manual, it will work.
Aqualite has 4 buttons:
1) top right (we will call it S1 like this manual does)
2) bottom right (this will be S2)
3) bottom left (this will be S3)
As I said the number 4) (top left) is only for light and we will forget it since it is not needed to set our watch.
Setting the minutes, hour, date month and day:
Press S3 3 times, or until the following are flashing in the display : TU and seconds
Set the minute: press S2 once and advance by pressing S1
Set the hour: press S2 and advance by pressing S1
Choose from AM (A), PM (P) or military time (H)
Set the date: Press S2 and advance by pressing S1
Set the month: Press S2 and advance by pressing S1
Set the day Press S2 and advance by pressing S1
Press S3 to bring you to the time display
Setting the chronograph:
The chronograph feature will store and add to the last recorded time interval up to 23 hours, 59 minutes and 59 seconds in the time display.
1. Press S3 (flashing in the display: SU, FR, SA)
2. Press S1 to begin. Press S1 to stop.
3. press S3 to return to the time display.
Setting the lap time:
The lap feature will record from 1/100th of a second up to 23 hours, 59 minutes and 59 seconds.
In the time display.
1. Press S3 (flashing in the display: SU, FR. SA)
2. Press S2 to clear setting
3. Press S1 to begin. Press S2 to stop.
4. Press S1 once and S2 twice to reset.
5. Press S3 to return to the time display.
Setting the alarm and snooze:
The time alarm features with a convenient snooze function which will sound 5 minutes after the first alarm in the time display.
1. Press S3 twice for the alarm mode (hour will be flashing): advance by pressing S1
2. Press S2 once (minute will be flashing)
3. Press S3 to set alarm and return to time display
3. Press S1 to deactivate alarm
5. After 5 minutes, snooze alarm will ring. Pres S2 to deactivate.
6. Press S1 and S2 at the same time to deactivate the alarm at any time.
To test alarm
In the time display
1. press S1 and S2 simultaneously for alarm test.
Hourly chime
Your chrono alarm sport watch ha the option of an hourly chime in the time display.
1 Press S2 and then press S3 to activate hourly chime
2. Repeat process to deactivate
Jul 23, 2009 | Watches
Need manual
Timer Setting
1. In timer mode press and hold "reset" to enter setting mode; hour will begin flashing
2.Press "st/stop" to increase hours;
3. press "mode" to advance to next setting value
cheers!
Apr 21, 2009 | Watches
How do I set the digital time on a mossimo analog/digital watch. Where do I find instructions?
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Legend:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
Press:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
Chime:
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
Chronograph:
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
-Or-
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Apr 08, 2009 | Watches
DECADE WATCH HAS NO SETTINGS MANUAL
If your Decade watch is like mine it has 4 push buttons (10, 2, 4 and 8 "o'clock" positions respectively; and one pull and turn stem (at 3 o'clock position) -
For the purpose of setting the watch and functions mentally label the push buttons as follows:
10 o'clock position "A"
8 o'clock position "B"
2 o'clock position "C"
4 o'clock position "D"
NORMAL TIME SETTING
1) In normal time readout press B (3x) to get to normal time setting mode: "SEC" will start flashing, press C for synchronization
2) Press D once: "MIN" will be flashing, press C to advance
3) Press D once: "HOUR" will be flashing, press C to advance ("A" is for am, "P" is for pm, "H" is for 24 Hour format)
4) Press D once: "DATE" should be flashing, press C to advance
5) Press D once: "MONTH" should be flashing, press C to advance
6) Press D once: "DAY OF WEEK" should be flashing, press C to advance
7) Press B once: Setting is completed, return to normal time readout
ALARM TIMES SETTING
1) In normal time readout press B (2x): Alarm time "HOUR" should be flashing, press C to advance
2) Press D once: Alarm time "MIN" should be flashing, press C to advance
3) Press B once: Setting is completed, return to normal time readout
ALARM FUNCTION
1) In normal time readout press C and D simultaneously: Alarm signal should appear
2) In normal time readout disarm alarm by pressing C and D simultaneously: alarm signal should disappear
Note: Alarm (when activated) will stop itself after 1 minute; or can be silenced by pressing D or press C to snooze for 5 minutes (operates for 1 hour)
CHIME
1) In normal time readout press D and B simultaneously: Chime signal should appear
2) In normal time readout disarm chime by pressing C and D simultaneously: alarm signal should disappear
CHRONOGRAPH (STOP WATCH FUNCTION)
1) In normal time readout press B once to get into "CHRONO" mode: press C for to start counting event -
While in Chrono mode there are two options
a) During a counting event: press C to stop counting, press D to clear and reset stopwatch to 0:00
b) During a counting event: press D to see a "split" time (IE first leg of a relay time is shown while the counting event continues, press D again to return to running counting event; press C at end of event, press D to reset stopwatch to 0:00
2) press B to return to normal time mode
Mar 27, 2009 | JCPenney Watches
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Rolex runs down
sounds like you need a new watchmaker, Your watch is designed to be worn 16 hours a day an rested for 8 while you sleep and this should keep it running. there are several different mainsprings that can be installed depending on the age and your activity level. I would be happy to take a look at it for you.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
Oct 09, 2007 | Bulova Watch
Watches Logo
15 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
