Question about Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
Computer refuses to start up and monitor just displays a floating box with "Check signal Cable". Tried with another monitor and CPU works just fine.
Had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Posted on Oct 28, 2009
  • 102 Answers
It shwos a compability issue with ur pc and monitor .somehow your sync signals are drop and not going to monitor at proper level...so u could replace your video data cable with new one.
or use a short length cable.it may solve your problem.
Posted on Jul 25, 2009
VGA Will not connect
Have you checked if the SyncMaster is compatible with a Mac? I do not use Macs, so I do not know. In the old times you had to buy everything Apple. You could try looking for an adapter to convert VGA or Digital to Mac Video.
Nov 27, 2013 | Samsung SyncMaster 2253LW Monitor
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Monitor was working fine last night but I think Microsoft did an update last night and i can't get the monitor to display. I get a check signal cable box that floats across the screen.Also do not have the...
Please unplug the monitor cable from the back panle of the cpu and replug it back again ensuring a tight connection.
this should take care of the problem.
Jan 22, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
HDM1 BOX FLOATING
This is telling you that you do not have a High Definition Mode source connected to teh screen.
Oct 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Flicker, even when no signal cable
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 03, 2009 | Samsung 226BW Monitor
Floating box says check signal cable
plug the blue cable connection into the VGA port (also blue) on the back of the PC and then turn it on. If you have multiple VGA ports and it doesn't work the first time try the other port.
If the cable is white check that you have a white DVI port on the back of your PC and use that port.
Jun 13, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Sansung 915N no video
the monitor gets the wrong signal from the computer (refresh rate too high or scan rate too high )
check the screen refresh rate from Display properties / Settings tab / Advanced button / Monitor settings
worse case: damaged hardware
Nov 07, 2008 | Samsung SyncMaster 915N 19" Flat Panel LCD...
New Monitor Installation
Does your computer have more than one video adapter installed. If so, try plugging into the other one.
Jan 13, 2008 | Samsung SyncMaster 216BW Monitor
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
2,791 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
