Question about The Computers & Internet
I can't seem to get the disk in the slot. - The Computers & Internet
ML3670 does not boot as it does not found an boot disk
Replace HDD (Red Flashing ).It seems you have unknowingly disturbed your Raid . If Possible take backup of your server.Reconfigure RAID and Freshly Install OS .
Apr 04, 2012 | HP ProLiant ML370 G4 Server
When I star up my computer Toshiba a135-S4427, it boots up and then goes to a blank black screen. I am unable to get to the log in screen. It just sits there, I can hear the processors and the fans...
Seems a problem with RAM. Remove your RAM from the slot and start the PC, long beep sounds are audible, then the RAM is OK, else time to buy a new RAM/ memory.
Else Try for the Hard Disk, Check the Hard disk in your's friend's PC, remove his Hard disk and insert yours, if the same problem arises, change the Hard Disk or if nothing happens, system boots,
it seems a problem with motherboard, Get it repaired by a expert or buy a new one.this will work.
Enjoy !!! Thank you for using Fixya !!!
Nov 14, 2010 | Toshiba Satellite A135-S4427 Notebook
I have a Philips HTS 6500 HTIB receiver. It started to show a "No disk" message when trying to play dvds. It seems like a common problem for this device. I have some experience with electronics but I am...
First, I commend you for taking the initiative and tackling this yourself. Every device that loads through a slot has a device that prevents a disk from being loaded when there is already a disk loaded. This is the device (the two pins) that you are describing. What you need to do is disassemble the unit again and while reassemling check at each step to make sure the pins are out of the way (usually down).
The pins are usually connected to the loading mechanism itself by gears, so it may be necessary to manually turn a gear or belt (very gently!) to get the mechanism to a position to accept a disk. Most likely this won't work by itself, but it might. If it doesn't, then separate the pin mechanism from the loading mechanism, get the loading mechanism into a position to accept a disk. That is, not in the position where the disk is being "read" by the machine, and put the two mechanisms back together, of course with the pins out of the way, and try it out. It may take a time or two to get the gears in just the right position to work right, but you seem to have the ability.
I hope this helps. If not, please post what happens, and i'll do what ever else I can to help.
Oct 13, 2010 | Philips DivX Ultra HTS6500/37 Theater...
My internal touchpad is frozen, and an extrenal mouse does not seem to work. Is the solution to use the Acer recovery disk, and how do I get the computer to boot from the disk?
try to use a PS2 mouse, it goes into the PS2 slot behind the notebook, the PS2 slot can be used for both (either) mouse or external keyboard
to boot from the disk u need to change BIOS settings...
i will give u full details of how to change BIOS setting if u r keen on that and if ur PS2 mouse dont work either...reply me
Dec 17, 2009 | Acer Aspire 3680 Laptop
What type of slots does mb have
mother board (MB) have different slots for different uses.
CPU slots, FDD slot, Primary disk/Secondary disk slots. RAM slots, HD connectors, CD/DVD connectors, monitor connector, USB slots, printer ports, internal modem slots, multimedia slots, HD Audio slots, PCI slots 1, 2, 3, etc
Dec 07, 2009 | Computers & Internet
How to insert memory card?
see manual which can be downloaded from www.brother.com
It might be that the Sony MS belongs within another cart slot.
Jan 18, 2008 | Brother DCP-110C All-In-One InkJet Printer
Dvd wont eject
hi jodestar,
i am having the same problem with my player. how did you end up fixing yours?
Sep 23, 2007 | Philips DVDR3455H/37B
CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
Jun 30, 2007 | Emerson MS3100 3-Disc CD Changer
Computers & Internet Logo
23 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
