Question about Hoover Vacuums
My Hoover Dual Power Pro carpet cleaner leaks continually from the front. I've cleaned and checked all connections.
    Problem Solver:
  • 15 Answers
Sounds like a missing or damaged seal/gasket/oring. Check carefully at source of leak.. maybe a seal or rubber gasket has shifted out of place.
Posted on May 03, 2017
Testimonial: "Yes, the gasket is very soft and doesn't seem to be sealing. It doesn't want to come off to replace it. How to fix it?"
My Hoover Max extract dual v cleaner worked fine cleaning the carpet but when it came to using the hose attachment for my sofa, there was no suction and the brush did not spin.
Hello, Kathy -
If you have not yet checked your owner's manual; the Troubleshooting section, I suggest you do.
If you do not have the manual, you can download a PDF (Adobe Reader) version here:
https://www.manualslib.com/products/Hoover-Max-Extract-Dual-V-6126442.html
This is the link to the Troubleshooting section in the manual:
https://www.manualslib.com/manual/389163/Hoover-F7411900-Steamvac-Dual-V-Wide-Path-Deep-Carpet-Cleaner.html?page=19#manual
I hope you made sure the dirty water tank was empty and that the filter screen is clean.
Jan 02, 2018 | Hoover Vacuums
My tank doesn't leak when not attached to machine, why does it leak when using upholstery tools?
THERE ARE O-RINGS THAT SEAL THIS , I THINK THERE RED/ORANGE IN COLOR FROM FACTORY IF I CAN REMEMEBER , REPLACEMENTS ARE AVAIL FROM HOOVER PARTS (OR SEARS) OR IF NOT BROKEN OR MISSING BUT ONLY NOT SEALING WELL , TRY A TOUCH OF PETROULEM JELLY ON THEM IT HELPS TO SWELL THEM UP TO SEAL BETTER
Oct 12, 2016 | Hoover F7411900 Maxextract Dual V Carpet...
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
How to clean suction area
If you are referring to the front nozzle area, Hoover has made a tool called a nozzle cleanout tool # 39514003
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Sep 13, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Why is thecleaner not coming out of carpet cleaner
You have to continually hold the trigger to release the cleaning solution. If you don't hold the trigger closed then you are running the vacuum in carpet drying mode. http://hoover.com/file/610/
May 25, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover carpet cleaner dual 5
Try this site for more information on this problem
It may just need a good clean out.
http://hoover.com/support/manuals/?q=SteamVac
Feb 05, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
310 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
