Question about Dehumidifiers
EC is flashing is the dehumidifier shot? Model KU34313/34513
How do I use the dehumidifier model 10 12 ec
Try Googling (brand)(10 12 ec)(manual) without parens.
Dec 10, 2017 | Dehumidifiers
Frigidaire dehumidifier shuts off with error code EC
Usually that is a sign that your dehumidifier is low in coolant. Could be something more serious, but usually would require to be charged back up (and sealed to prevent coolant from leaking out).
Jul 09, 2017 | Frigidaire Dehumidifiers
My Humidifier is 2 years old. It worked fine and now there is an "EC" code on panel
Unit malfunction. Dehumidifiers are designed to function within specific temperate ranges, usually between 50 and 80 degrees. Make sure that the ambient temperature of the room is within the range of your dehumidifier. Try not to run it continuously.
Jun 06, 2015 | Midea Westpointe 50 PT White Electronic...
I have a model KU 34313 Kul dehumidifier and i cannot get it to stay running , I plug it in and it runs for 2 minutes and then shuts off? cannot find manual
We too have the same problem but it is with the KU34513 Model it may last a whole 15 minutes max then shots off with ERR message.
We bought it after last recall.Now there is another recall. Is this a safe model? Fix or replace?
Jun 28, 2014 | KUL 50 Pint Dehumidifier"
EC appears and it doesn't draw water
I contacted CE North America customer service regarding this issue for same unit. They suggested disconnecting for 10 minutes, then reconnecting, turning unit on, and changing settings and run fan on HIGH or TURBO until the EC code goes away. This didn't help with my unit. If this doesn't work, there is no repair provided. Customer Service recommended returning unit to purchase location if under warranty (1 year), however a copy of the original purchase receipt is required. Suggest a call to Customer Service Center at 866-915-1212.
Jun 01, 2014 | KUL 30 Pint Dehumidifier
Dehumidifiers Logo
82 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
