Question about Briggs Garden
Briggs and stratton 21HP engine surges, wont idle. 2013 Platinum 21HP 331877-4449-G5 w/ 20 hrs on it.
I have replaced fuel with fresh, cleaned & re-oringed(all) carb, changed fuel transfer tube, tried diff carb body, checked for vac leaks, checked FW key,checked and adjusted valves (Int was 0 lash),switched to grav. feed fuel supply to test, checked for bad hd gasket, all to no avail!! I can hold throttle still, but engine runs lean.Not my first mower rodeo, but I am baffled!! Only thing not done is ck gov adjustment. Honestly..... forgotten the process and specs.
    Top Expert:
  • Briggs Master
  • 77,939 Answers
Dirt in the carburetor jets or fouled fuel.
Posted on May 03, 2017
I have A briggs & stratton 300 engine. When I start the motor surges at idle and full throttle.
Leaking head gasket or intake gasket
Try a new spark plug & fresh fuel first,
& clean the air filter
Sep 26, 2014 | ROPER OUTDOOR POWER PRODUCTS Weedeater 20"...
John Deere L111 from 2004 surges in idle. Have replaced plugs, fuel/oil filters, fuel pump. Still does it.
Cleaning the carburetor is a good starting point. There is two versions the Briggs that were used on this mower. One had a single barrel and the other had a two barrel version. Both were Nikki carburetor that main jets that are held in place by tiny o-ring that shrink causing the jets to leak extra fuel causing surging.
Aug 11, 2014 | Garden
New 24 hp B&S engine running out of fuel
There is a restriction somwhere before the fuel filter, this is assuming gravity feed and there is no fuel pump for the engine.
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine is surging when in idle
Sounds like the low speed idle circuit is clogged or the inlet needle tip is clogged in the carb. About the only way to clean these is disassembly.
May 10, 2010 | Briggs & Stratton Briggs Stratton Intek V...
clean out the carburetor jets re-assemble then adjust fuel mixture screw until it runs correctly
Apr 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
Mar 14, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
59 people viewed this question
Top Briggs Garden Experts
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
