How much weight can you put on a burner - Computers & Internet
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    Range leisure
    Most likely cause is food on the burner or down inside the burner holes or possibly in the gas tube that feeds gas to your burner.
    If it were mine Id take off the burner and gas feed tube going to it and clean them out with soap and water and get a small drill bit about the same size or a little smaller than the holes that are around the burner and push it through the holes by hand and rotate them by hand in the little holes and verify they are clean and unobstructed.If its a light weight burner like aluminum DO NOT Put the drill bit in a drill and drill the holes out, Some burners are so thin and cheep you could easily drill an extra unwanted hole in the back of the burner.If its a heavy duty cast iron burner you could use a drill if you are very carefull .there could possibly be greese or something inside the burner itself ,try to clean it out if possible.Some times insects like a small house spider will make a web or cacoon or something in there if you dont use it very often.
    So after cleaning the burner ( inside and out) , and the gas tube,with soap and water, you dry it off with a clean cloth . If you have access to an air compressor with a blow tip, you would thoroughly blow out each hole on the burner ,and front and back of every other nook and crany or hole there is very thouroughly .After all that reasemble itand try it out. If thats not the problem then I dont know what it could be unless some how your gas supply is getting contaminated with something else before it gets to your stove . If this would be the case then all your gas burners will burn black. If it is only one burner that burns black then there has to be something wrong with that specific burner or gas supply tube going to the burner. Good luck with it ,Sincerely, Keith
    Sep 05, 2012 | Rangemaster 110 (Dual Fuel) Dual Fuel...
    My LG DVD Write is not able to read DVD after cleaning the lens with lens Cleaner CD.
    You most likely scratched the lens, which means the drive is a big paper weight now.
    Feb 18, 2011 | LG GSA-H55N DVD-RAM Burner
    Can get burners to light but there is no presser.cleaned and blew out all parts, replaced regulator with no luck. what should i try next
    Try turning off the tank, disconnecting it, then reconnecting it. Then very slowly turn the gas tank back on. Also make sure your tank isn't almost empty! The empty weight of your tank is stamped on the collar as T.W. (tare weight). 1 gal of propane weighs 4.25 lbs. Put it on a bathroom scale and see if it weighs less than the tare weight + 4.25 lbs. Let me know if that solves it. If not, we'll dig deeper. Douglas
    Jul 13, 2010 | Weber Grilling
    What is the weight of an endeavor 24
    According to the website the weight is 44kg/97lbs.
    This is the link to the website:
    Kind regards!!
    Jan 06, 2010 | Rimage Endeavor (555101102) (555101102)...
    How much trailer weight can a 200 Saturn LW300
    The engine is not the limitation, the actual chassis wasn't designed with towing in mind. If you were to pull more, you run the risk of damaging the body.
    Oct 14, 2009 | MicroBoards Saturn (SPS-1007-01) Burner
    Computers & Internet Logo
    24 people viewed this question
    David Payne
    David Payne
