Question about Bionaire Humidifiers
Just bought bionaire humidifier bu8000 it wont start the machine lights up and beeps 10 times then stops its full of water help please
    Top Expert:
  • Bionaire Master
  • 77,499 Answers
Return it for warranty repair.
Posted on May 03, 2017
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
Need two tank caps with gaskets
Fixya does not sell replacement tank caps.
Sep 03, 2017 | Bionaire W6 Whole House Humidifier / Air...
The water from my bionaire humidifier keeps leaking well not leaking pouring out of the humidifier base. I checked and no there is no cracks on the water tank and it does not leak from the tank itself. But...
try to check the insulation of your drain pan because of your water came from your unit is cold that create moist on the tank when hit by hot air from sorrounding air apply insulation on the tank.
Mar 27, 2011 | Bionaire Humidifiers
Need product manual for bwm2600 humidifier - red light is on
http://www.bionaire.com/Manuals/MANUALS/BWM2601-U_43_27612514.PDF
here is the website that you can download the manual if you have any other questions please let us know
Jan 31, 2010 | Bionaire BWM2600-UC Humidifier
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Bionaire BCM 6000 tower leaking issue
Thank you for the follow up but there was a price at the end for my question so I decided to find out myself. I bought this product which is not the greatest and if on top of that I have to pay for a little information that's a bit far !
Regards,
Michel
Feb 02, 2009 | Bionaire BCM6010RCU 3.5 Gallon Tower...
Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Christiaan
Feb 07, 2008 | Bionaire Warm Mist BWM0400-U Humidifier
Need help humidifier doesn't stay on
I've had this problem before and with mine, the issue is the water is not making its way into the correct reservoir on the bottom of the machine. With experimentation, I discovered that my tilting the machine slightly upwards on the righthand side corrects the problem (i.e. put something aprox. 3-5mm thick underneath the right side of the machine). You will hear that the water "move" to the left side of the machine and thus ensuring proper operations. I think this is a design flaw (for some machines) as clearly I have the same problem too.
Pc
Dec 19, 2007 | Bionaire Cool Mist BCM4530 Humidifier
Bionaire Bcm630
Same problem — junk.  Will return it to Sears (Costco was out).
Nov 18, 2007 | Bionaire BCM6010 Humidifier
Humidifiers Logo
146 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
