Question about Sony Playstation 3 (PS3) Console
Same issue, cannot connect to my wireless connection at home...
  • 250 Answers
1.Try upgrading the firmware on your router
2.unplug your router and/or modem and plug back in see if that makes any difference
3.connect gaming adapter directly to the computer, reset gaming adapter back to factory default settings, assign a static IP address on computer, for e.g. 192.168.1.10 subnet mask 255.255.255.0 default gateway to 192.168.1.1, logon to gaming adapter's setup page and edit the the wireless settings and IP address according to wireless router or Access Point and save the settings...remove the static IP from the computer and power cycle the n/w...open or trigger 10070-10080, 6000-6999 ports on the router for PS3 and check whether it works or not.
Posted on Jul 25, 2009
Connected to wifi but no internet connection
Wireless networks have become an increasingly popular way to access the Internet. Connecting to a wireless network allows you to browse the Internet without having to physically connect any cords to your computer.
Troubleshooting wireless connectivity can sometimes be confusing, because even if a wireless network is not able to bring you to any web pages, often your computer's wireless card will still connect to the wireless network that is being broadcast.
In other words, a wireless network will read "connected" even if it is not connected to the Internet.
Connect to a different wireless network. If there is an alternate wireless network within range of your computer that you legally are able to use (a free public Wi-Fi rather than your neighbor's wireless network, for instance), try connecting to it and browsing the Internet.
If the same issue occurs on the alternate wireless network, you may have an issue with your computer's wireless card or with your Internet browser.
If you are able to connect to the alternate network but still not able to connect to your own, the problem is most likely localized to the wireless network you use at home.
Reset all devices.
The great majority of Internet connection issues can be resolved by a simple reset of all the devices in your home network.
Locate the power cords of both your modem and your wireless router and unplug them (if you use a modem/router combination, simply unplug its power cord) for a full 30 seconds.
Plug them back in and restart your computer.
Try to connect to the Internet using your wireless network after your computer has booted back up.
If the connection still fails, some further troubleshooting is required.
Bypass your wireless router.
If your computer's wireless card is connecting to your wireless network of choice yet you are still not able to access any websites, there may be a connection issue on either your modem or router.
The easiest way to locate the problem is to temporarily eliminate the router from the network. Locate the Ethernet cable that connects your modem to your router and unplug it from the router.
Plug the cable directly into one of the Ethernet ports on your computer and reset the modem in the manner described above.
Now try your Internet connection again. If there is still no Internet access, the problem is most likely with your modem or your computer; contact the technical support department of your Internet service provider (ISP) for further assistance.
If the modem goes online directly connected, your router is causing the problem and may need to be reconfigured. Contact the router manufacturer for further assistance.
Hope this helps
Oct 24, 2012 | Cisco Linksys WRT54GX4 WirelessG Broadband...
Suddenly unable to connect to wireless network
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Apr 02, 2012 | Dell Inspiron M501r Laptop Computer (AMD...
Data connection refused
After cancelling the data plan with the wireless service provider, the message Data connection refused appears at the top of the Home screen on the BlackBerry smartphone instead of the branding of the wireless service provider.
This is caused may be you were previously subscribed to a data plan through a wireless service provider, and the BlackBerry smartphone is still configured to attempt to access the data network.
To resolve this issue, you need to turn off the Data Services feature on the BlackBerry smartphone. To perform this, you need to complete the following steps:
  1. From the Home screen, open the Options menu.
  2. Click on Mobile Network or Network.
  3. Set the value of the Data Services field to Off.
  4. Open the menu and select Save.
  5. Return to the Home screen.
  6. Turn the wireless transceiver off and then on again.
To enable (turn on) the wireless transceiver on the BlackBerry device, go to the Home screen and select the Turn Wireless On icon or open Manage Connections and select the wireless connection to be enabled. Once enabled, the icon will display Turn Wireless Off .
To disable (turn off) the wireless transceiver, go to the Home screen and select the Turn Wireless Off icon or open Manage Connections and select the wireless connect to be disabled. Once disabled, the icon will display Turn Wireless On.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
Windows 7 Wireless connection problem
Disable IPv6 from your Laptop & then check ur Wireless Connection...
Also let me know the status...
Nov 12, 2009 | Microsoft Windows Vista Home Premium with...
Brand new Dell netbook won't connect to internet (at home). Connects fine at work. Wireless strength is good at home but no internet connection. Husband's notebook connects just fine so it appears to be an...
No, it's probably because you have setup a wireless home network with security in place.
Go through the settings on your husband's notebook settings for your home network and set your Dell up the same way. You will need to know the SSID for the wireless network, security type and key to set it up.
Oct 28, 2009 | Dell Computers & Internet
Toshiba Satellie P305D Wireless Connection Issue
If you are having an issue with your wireless at home, try changing the security settings on your router i.e changing the password, or encryption type.
Mar 16, 2009 | Computers & Internet
HTC will not connect to wireless at home
Hello Devin, give me a chance too! may be my technician help you to fix this issue. Dial our company customer care number +1-800-620-8060 (toll-free). We surely help you!
Thanks
John
May 08, 2017 | HTC Touch P3450 Smartphone
Router connections
If you have a laptop in home 2 that is able to connect with NO issues whatso ever I would almost think its a security issue... Do you use the same kind of encryption on both home 1 and 2? (ie WPA or WEP)
Dec 31, 2007 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
