Question about Baxter Ovens
Baxter 300g oven has air flow fault.how to troubleshoot?
3 Suggested Answers
SOURCE: I have a problem with
Check to see if your draft inducer (exhaust fan) is running, if it is then you could have a dirty/bad air switch, the component with the small black hose running to it and the two wires on the face. To check an air switch using a multi-meter set it to 40 VAC and place a lead on each terminal, if you are getting a voltage reading over 1 volt, replace the air switch, if you have zero volts, the air switch is closed and working. Aside from a bad exhaust motor or air switch there could be many things causing that error.
Posted on Dec 30, 2011
SOURCE: I have a problem with a Baxter OV300E Oven.
Check to make sure the draft motor, directly above the control panel in the front right corner, is running. If it is running then you could have a dirty air switch, if you open your control panel you will see a metallic disk with a black rubber hose and two wires going to it, this is your air switch. Try disconnecting the hose and blowing out the air switch and hose with compressed air. If this doesn't work you may need a new air switch. If the motor isn't running at all you could have a bad motor or a bad ignition module which powers the fan.
Posted on Jan 13, 2012
I need wiring digram for baxter oven ov300e
Request the wiring diagram directly from Baxter.
Feb 23, 2017 | Baxter Ovens
I have a problem with baxter oven ov310g powering off automatically. Have to turn breaker on and off again to reset. Any advice?
it could be a element blown to earth, if breaker is tripping when oven off wiring fault
Dec 09, 2016 | Baxter Ovens
Baxter oven does not fire up at all
So many things it could be. A bad high limit switch. A bad air proving switch. Maybe the burner motor overload had tripped. And that's not even half of the components that might be preventing it from working. It's best to call an experienced service provider.
Oct 14, 2016 | Baxter Ovens
Baxter oven not working
Hobart owns Baxter. You'll have to call Hobart.
Feb 14, 2014 | Baxter Ovens
BXA2G oven is not heating properly and also air-flow on display board is not stablising and also both set temperature and oven temperature is flashing.so can you email me aa manual please
Your temperatures will begin flashing after the oven attempted to heat for 10 minutes without successfully increasing in temperature. Sound like you are having burner issues and should call a licensed burner technician to have it serviced.
Aug 05, 2011 | Baxter BXA2G Stainless Steel Gas Single...
I have a problem with a Baxter OV300g Oven. The Automatic Ignition System keeps Flashing 1-flash Air flow problem, can you help me with this. Thank you.
Jul 30, 2011 | Baxter OV300E Stainless Steel Electric...
Wich is the power supply 120v, 208 1 phasse or 208v 3 phase.
Most Baxter BXA ovens have separate power supplies, usually 120v for the controls and lights, a 120v output on a circuit breaker for the roof fan, and a 208VAC 3 phase supply for your convection motor. Older Baxter ovens may have a 3 phase service disconnect inside the electrical/burner compartment, if I recall correctly the BXA models do not and the only way to shut it off is via the 3 pole breaker at the service panel.
Feb 04, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Need to set clock for daylight time on baxter oven ov300e
With the oven on hold the time up or down arrows until the time begins to change.
Nov 07, 2010 | Baxter OV300E Stainless Steel Electric...
I have a problem with a Baxter OV300E Oven. The Automatic Ignition System keeps Flashing 1-flash Air flow problem, can you help me with this. Thank you.
Feb 20, 2009 | Baxter OV300E Stainless Steel Electric...
Ovens Logo
47 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
joneable
Level 1 Expert
Jerry Kramer
Jerry Kramer
Are you a Baxter Oven Expert? Answer questions, earn points and help others
