Question about Kitchen Ranges
My bush white range cooker which is 6/7 months old is great but the descriptive logos above each cooker knob are disappearing. can u send replacements please.
SOURCE: 6 qt. slow cooker.
FYI, the recall is not for the 169143 model:
"The recalled slow cookers include the 4.5-Quart Oval and 6-Quart Double Dish models sold under the General Electric (GE) brand name. The model name is printed on the front of the units. The 4.5-quart unit has model number 106661 and the 6-quart unit has model number 106851. Both models have series codes A through D, which are printed on the bottom along with the model number. The base of the slow cookers is white with an olive or honeysuckle graphic."
I too, have the 169143 model. In fact, I just received it for Christmas. I loaned it out and the glass lid broke. I just got off the phone with the division of GE that handles the Walmart products (these slow cookers were made specifically for Walmart), and unfortunately, we are out of luck. You cannot get replacement parts (including lids) for the slow cookers made exclusively for Walmart. The only option is to buy a whole new slow cooker. Grrrr! So much for a 3-month old slow cooker that is now useless. If it was any other shape than rectangle I would just retrofit with a different brand lid, but those rectangular ones are near impossible to find.
Posted on Mar 18, 2008
SOURCE: White horizontal lines on top of the screen otherwise picture OK.
This is a symptom of what is generally a leaky or open filter capacitor in the vertical sweep circuit. Vertical foldover, where the image actually is reflected upside down an inch or so into the top of the picture, is common in this problem. There is an IC that controls the signal and sometimes it needs to be replaced, but more often it's one of the filter capacitors nearby. Any competent technician can fix this problem and the capacitors only cost $2-3 or so if you can find the correct value at Radio Shack (that's if you pay full retail for them). A good service tech will probably have these on hand. Testing them is easiest with what's called an ESR meter (stands for Equivalent Series Resistance) and the better ones don't require you to unsolder them from the circuit board before testing. The most expensive part of this repair is going to be the technician's labor. They're good TV's, this is just a problem common to most TV's in general - mostly due to aging of the capacitors from years of heat. A higher quality replacement capacitor will solve the problem for the life of the set.
Posted on Apr 27, 2009
barkencoa
  • 3463 Answers
SOURCE: my grill on my oven is melting the knobs and the
I assume that you are grilling with the oven door open and not closed, if you are grilling with the door closed, then this will cause an overheating problem,if this is not the case, then I would suggest that the grill regulator is faulty,. and needs replacing.
It not covered by health and safety rules.
Please leave any comments you may have, as I like to know if my comments are appropiate.
Thanks.
Posted on Nov 25, 2009
  • 5 Answers
SOURCE: Rival crockpot knob
Try the hardware store. Look at the dimmer knobs.
Posted on Dec 19, 2009
  • 153 Answers
SOURCE: Only works speeds 6-8. Turns off when moving knob
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
You need to adjust the mixer speeds:
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Posted on Jul 26, 2011
I have just bought a second hands bush AG66TW gas cooker. Unfortunately I haven't got a manual for this. Could you please let me know where I can get this. Thank you
[PDF]bush cooker manual.pdf - WordPress.com
https://tisinglowthpho.files.wordpress.com/2015/.../bush-cooker-manual....
Bush Cooker Manual manual for bush ag66tw gas cooker. Asked by dougie on 03/15/2015 0 Answer. ManualsOnline posted an answer 5 months, 4 weeks ago.
Oct 26, 2015 | Kitchen Ranges
Knobs are distorting with heat
It sounds like either a bad design or a leaking seal,the knobs are above the oven?If it is the door might not be sealing good allowing heat from the oven to escape upwards heating up the knobs.It is not normal.
Apr 29, 2012 | Stoves Kitchen Ranges
My Bush 24" TV is only showing a white screen !
Check the video output voltage to CRT board. It might be absend.
Apr 26, 2012 | Bush Televison & Video
White knob just broke off rival 37601 glass lid crock pot . need replacement
I found universal replacement knobs at:www.goodmans.net. Thank you for your help.
Jul 09, 2009 | Rival 37601 6-Quart
Rival crockpot knob
Jan 17, 2009 | Rival 3355 5-Quart
Rival crockpot knob
Try one of the following sellers:
To contact the manufacturer, try calling 800 #. 1-800-323-9519 (US number) for replacement parts or try www.crockpot.com
Rival Crock Pot Replacement Parts from MarBeck.com
Crock Pot Replacement Parts | Slow Cooker ...
Oct 20, 2008 | Rival 3060 6-Quart
Replacement Knobs for the Rival Slow cooker
I HAD the problem with the handle snapping off the lid of my oval 6qt lid - until I spent 10 minutes and $2 in the cabinet hardware section of Home Depot. Now I have a stylish silver & white handle on my crock pot lid. The bolt and grommet were re-used, several little tiny o-rings were added as spacers, along with a drop of Loc-tite.
Oct 31, 2007 | Rival 38651-C 6-Quart
3040 VG
I need a knob for a slow cooker 3040 Rival terragno@comcast.net
Oct 31, 2007 | Rival 3040-VG 4-Quart
Kitchen Ranges Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
