Question about Magnavox Televison & Video
Magnavox 15MF227B/27 is very slow in assembling a picture upon start-up. Works well after several minute warm up.
No picture or a frozen picture is displayed. What's wrong and is it economically feasible to repair?
2 Suggested Answers
  • 3 Answers
SOURCE: magnavox hdtv has very dark picture
I had a problem with my Sony going on and off. Went away when I moved plug from Monster Power Strip to the wall outlet.
Posted on Dec 08, 2008
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
2002 Big Bear 400. Dies after a few seconds upon startup
sounds to me the valves are not properly adjusted,..like their to tight,...i had run into this in a japanese car once,...check it out and let me know,.....cracklin joe
Jan 10, 2010 | 2002 Yamaha SR 400
My 15" magnavox LCD tv turns off and on by itself. It also looses programed channels. can you help with a fix? thanks, Steve
very common in this unit you will see a bunch of puffed up can like caps on the mainboard the values are on the sides chenge them out and you will be fine
Nov 18, 2009 | SNK Magnavox 15MF227B 15 in. LCD TV
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Tv goes off after it warms up AND pic. goes SHORT and WIDE prior
im betting the vertical deflection is failing, a capacitor that is in the vertical deflection circuit may be dry and as it heats up shorts shutting the tv off.
Dec 12, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox hdtv has very dark picture
Dec 08, 2008 | Sony KP-51HW40 51" Rear Projection...
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Nov 29, 2007 | Sony KV-27XBR45 27" TV
60 inch philips magnavox
When you first turn on the tv, It goes from small picture to full screen and several corors around screen for a few minutes,I guess until it warms up? Could you please help? Thanks!
Mar 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
