Question about Troy-Bilt Garden
My Troy-bilt lawnmower model number 11A-A2BM711 HAS GAS HAS OIL doesn't start please help its only 3-4 yrs old
    Top Expert:
  • Troy-Bilt Master
  • 80,417 Answers
You need to pull the spark plug and verify it has spark, my guess is that it has no ignition spark due to a failed igniter unit or pickup coil.
Posted on May 03, 2017
I have a brand new mower that wont start
Sharon, if it is brand new. be sure it has gas in it. and check the oil. if the oil is low it wont start. it has to be between the low and full lines. if it has a primer bulb you will have to prime it 5 or 6 times. if this don't help give a little more info on what is or is not doing and i may be able to help you further. good luck
Apr 15, 2018 | Troy Garden
Have a troy bilt model # 47282 hard to start what could it be
is the gas any good?is it newer than 30 days old gas is only good for 30 days in small engines
Apr 24, 2012 | Troy-Bilt Chipper Shredder
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Briggs & Stratton 650 (Model 120000) lawnmower engine on a Troy-Bilt CSV060 lawn vacuum/chipper/shredder. Was stored for several months with no oil/gas. Recently got it out and filled oil/gas. Would...
you are clearly burning oil. did you overfill? or tilt the unit so that engine oil went into the carb through the breather? now the carb may be soiled/partly clogged, you need to clean it. esp. the idler air part may be at fault. sometimes it is possible to run it at high rev until the fuel has washed out the oil, but better clean the carb and replace the air filter.
Jul 08, 2017 | Troy-Bilt Heavy Machinery
Do you mix the gas and oil together with the Troy-Bilt4 cycle TB575SS. Lost directions. Thank you
No. You do that for a 2-stroke engine. Your engine should have oil in the crankcase and you just need to check the level of it and add gas to it like a regular lawnmower engine.
Sep 06, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What tool should i use to change the oil on a push Troy Bilt lawmmower Model 11A-439R766 XVS 6.5HP 190CC
The drain plug is made to fit the square end of a 3/8" wratchet extension.
Jun 14, 2010 | Garden
Old (1981)Troy Prof. 8hp tiller runs 30 sec. and stops.
Clean the carb and if this machine was kept outside all winter make sure no water in tank. I realize you stated that you removed old gas but how it was removed is the key. Try the carb thing first though.
Apr 28, 2010 | Troy-Bilt Pony Garden Tiller
I have a Troy Bilt Bronco 5.5 hp that will start and run about 5 mins then cut off the it will restart for like 2 seconds. It's got new plug and clean gas, it's also only about 3 yrs old. Any ideas
Sounds like fuel starvation
Check / remove carby / strip down / check for blocked jets for contamination.
Check spark is present.
Is correct heat range
Mar 16, 2010 | Troy-Bilt Pony Garden Tiller
My lawnmower won't start
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
100 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
