Question about Proscan Televison & Video
My Proscan PLDED3257A won't turn on unless I press the remote ON button ten or twelve times. I can't turn the TV on manually either. I have new batteries in the remote. Please help me. Thank you.
    New Friend:
    Problem Solver:
  • 9 Answers
TOP TIP: As you're pressing any of the buttons on the remote control, point it to a camera on a mobile phone or any camera where you can see a screen. If it's working the camera picks up the infrared and easily visible on the screen, invisible to the ***** eye. Try giving battery contacts a rub with some fine grade emery paper. Also, the negative side of the battery fits toward the 'spring' end of the battery compartment. To make sure there's a good contact, gently pull the springy side to stretch it out a little to make the battery a good firm fit. Hope this helps.
Posted on May 03, 2017
    Top Expert:
  • Proscan Master
  • 77,932 Answers
I would try replacing the remote first. You can get them here
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
Why won't tv turn on by remote or power button unless we try 4-5 times?
My TV has the same problem.
At first, it was an issue with the button itself, somehow some gunk got down under the button and kept it from pressing down all the way most of the time.
A few days after we fixed that, it started to mess up again, this time it was an issue with the way it transmitted signal to the TV.
If the button being blocked isn't the issue, replace the batteries. If the batteries aren't the issue and you don't have a soldering gun, then you'll need to purchase a new remote.
I bought one from walmart for ten dollars and it works just fine for basic use.
Jan 15, 2013 | Televison & Video
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: . The direct link is .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
I still have not figured out how to program the exact code in the crk76DBL1.
However, I did figure out how to use the code search for the TV
1) Turn on the component you want to control (TV, VCR, DVD)
2) Press and hold BOTH the component button on the remote and the On-Off button
3) The On-Off button remains lit. Now press Play (The On-Off button will blink)
4) If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
5) When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
6) To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
I hope everyone finds this helpful and saves people time and frustration.
Feb 22, 2008 | RCA DIRECTV Satellite Remote Control
Need Code for Proscan TV for my URC-3021 All in one remote
Hello, follow this link to download the manual and the codes for your remotes:
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
(For replacement remotes visit
Jan 07, 2008 | One For All URC-3021 Remote Control
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
