Question about Nokia 5300 Grey Cellular Phone
Automatic power switch off problem - Nokia 5300 Grey Cellular Phone
My samsung s5300 automatic turn off problem
Posted on Jul 05, 2012
  • 20 Answers
Problem in your strip.... or else software problem....
Posted on Jul 25, 2009
How do u switch power usage from battery to a power outlet on a 1989 winnebago econoline 350??
Your owners manual is available online. It says the connverter automatically switches in when the power is connected. If the breakers are on, this should automatically power up the 110 outlets. Have you located the converter?
Mar 05, 2017 | RVs
Unlock Child lock on nissan if the lock is on and dont open from outside
All doors lock automatically when the vehicle speed reaches 15 MPH (24 km/h).
? All doors unlock automatically when the ignition is placed in the OFF position.
The automatic unlock function can be deactivated or activated. To deactivate or activate the automatic door unlock system, perform the following procedure: 1. Close all doors.
2. Place the ignition switch in the ON position.
Within 20 seconds of performing Step 2, push and hold the power door lock switch to the position (UNLOCK) for more
than 5 seconds.
4. When activated, the hazard indicator will flash twice. When deactivated, the hazard indicator will flash once.
5. The ignition switch must be placed in the OFF and ON position again between each setting change.
When the automatic door unlock system is deactivated, the doors do not unlock when the ignition switch is placed in the OFF position. To unlock the door manually, use the inside lock knob or the power door lock switch (driver's or front passenger's side).
NOTE:
The automatic door unlock function can be changed using the Vehicle Settings in the vehicle information
Sep 30, 2016 | Nissan Pathfinder Cars & Trucks
Replaced battery, now auto windows wont come up auto automatically
If on a GM car the battery has been disconnect the windows may need to be reprogrammed
The following steps explain how to program the side door window regulator motors:
  1. Press and hold the power window switch until the window is fully DOWN. Continue holding the power window switch for approximately 3 seconds.
  2. Press and hold the power window switch until the window is fully UP. Continue holding the power window switch for approximately 3 seconds.
  3. The power window regulator motor is now programmed for the express function.
  4. Repeat this process for all of the power windows.
Dec 01, 2015 | Cars & Trucks
Generac generator won't turn off in automatic
It is possibly a transfer switch issue, not the generator control board. Have an electrican kill utility power, let it start and run, then disconnect the sensing wires in the ATS. If it stops problem is ATS
Mar 01, 2015 | Generac Electrical Supplies
HOW DO I install a 3 phase generater to an mcc to automatically change over to generater power in the event of a mains power failure?
You would need a three phase automatic transfer switch.
Your local electric company usually requires you the have these automatic transfer switches install by a license electrician.
Dec 03, 2014 | Electrical Supplies
Automatic transfer switch not transfering power to home
YOU MAY WANT TO CHECK THE RELAYS THAT ARE IN THE TRANSFER BOX
Dec 15, 2013 | Generac Guardian 200-Amp Automatic...
Nokia 5030c-2 switch-off and on automatically
Hi if your phone switch on itself without pressing the power button,then the problem comes from the sort of keypad IC or power button point.The only thing you can do is to clean the power button point.Otherwise contact mobile repairing shop.....Good luck
Jun 06, 2012 | Nokia XpressRadio 5030 Cell Phone
I am trying to add an additional PoE device, put it will not power up. How can I tell the switch to power up a specific port, or put the switch into automatic mode?
Are you within the power budget?
Power feeding of Ethernet is limited for fixed 10BASE-T/100BASE-TX ports. The solution can provide maximum output power per PoE port up to 15.4W on 12 ports or 7.5W on 24 ports simultaneously. The Switch provides independent overload and short-circuit protection for each port, LED indicators for power status per PoE port, and supports IEEE802.3af MIB for Power over Ethernet functionality.
For each attached 802.3af-compliant device, the Switch automatically senses the load and dynamically supplies the required power. The Switch delivers power to a device using the two data wire pairs in the twisted-pair cable. Each port can provide up to 15.4W of power at the standard -48 VDC voltage.
Source: http://www.cisco.com/en/US/products/ps9967/products_qanda_item09186a0080a36afb.shtml
Mar 19, 2011 | Cisco Systems 24-Port SF 300-24P 10/100...
I'm wiring a briggs and stratton 1918 automatic transfer switch. how do i wire the chosen circuits to be powered? would they be wired exactly as if they were at the main panel?
With any transfer switch, automatic or otherwise, there are three (3) connections:
1. The normal feed (from your local utility)
2. Emergency feed (from your generator)
3. The load (your power panel or other electrical loads)
The transfer switch should be marked "N" for normal, "E" for emergency, and "L" for load
If you want individual circuits, then you will need a second power panel to separate the circuits.
This can be tricky, and if you are not familiar with transfer switches or emergency power, it's best left to a licensed electrician.
Jun 21, 2009 | Briggs & Stratton 50-Amp Automatic...
Series165 Automatic Transfer Switch with faulty controller
You have a faulty component in the controls somewhere. Sometimes you can find it by unhooking things, then try powering up until it stays on. Then you isolate it down by gradually hooking things back up until your problem comes back.
Jun 20, 2009 | RTO ASCO 165 Series 200A Automatic...
Nokia 5300 Grey Cellular Phone Logo
225 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
