Question about Garden
HOW DO YOU REMOVE RHE STOP CONTROL CABLE FROM THE FITTING ON SIDE OF MOWER WITH A SELF PROPELED SYSTEM MODEL 675 2009
  • 744 Answers
SOURCE: toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Posted on Mar 19, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
bbreton
  • 437 Answers
SOURCE: Lawn mover will not start, was flipped over
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Posted on Oct 07, 2009
  • 430 Answers
SOURCE: I have a Toro walk behind self propeled mower.
Was it the 'flywheel key' ? Does it yank the rope out of your hand violently when you try to start it?
Take the top shroud off, remove the flywheel nut, washer and screen. Remove the flywheel by threading the nut back onto the crank end to protect the threads and with a brass hammer ( and while lightly prying with a screwdriver from behind the flywheel) and a few good solid taps on the end of the crankshaft the flywheel should free up.
Remove the flywheel and inspect the key. Even .001th off will make the motor run funny or not at all.
Posted on Dec 09, 2009
" How to put belt on Bolens self propeled/ self muliching 21' push mower
should be some sort of tensioner device or spring that would need to be slacked off in order to facilitate removal try that
Jul 24, 2014 | Troy Bilt Tiller Bolens Swivel Post Pn...
Self Propeled Doesn't Work
inspect the belt then check the cable operation
Jun 18, 2012 | Toro Lawn Mower With Toro Power Tools
I have a troy-built model `TB230 self propeled walk behind mower. Mower just stopped propelling itself, no noise gears seem fine. But when I checked belt it was on but it looks like it is just sitting on...
There is a problem with some types of belt driven self propelled mowers. One is grass clippings and dirt get clogged in there, dry out and act like plaster. But if yours is clear of debris...then what has probably happened is good old "stretching of the belt" even a tiny bit. And unfortunately all belts stretch eventually. If you do not see a obvious adjustment to increase the pully spacing then take a good look at the cable that you squeeze to make the mower move. Up by that "go" lever there is usually s small screw or an "adjuster nut" to tighten the cable up. (Cables stretch too! just like belts.) you should be able to adjust it at least twice before you'd have to get a new cable or belt. So place the belt back onto its pulleys, then (mower off!) pull the "Go" lever and watch the pulleys move. You'll get the idea immediately. So, if no adjustment at the pulleys, look to the cable adjustment up at the lever area. Let me know.
May 10, 2010 | Garden
How do you tighten the control cable on a Troy Bilt mower?
Usually near the end of the cable there is a squeeze clamp on the side of the cable. Losen the mounting screw (DO NOT remove it) and slide the cable in the direction that will expose more cable. Tighten the mounting screw and test the control. It is really pretty simple.
Thanks for using FixYa.
Kelly
Apr 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a Toro walk behind self propeled mower. Last summer my sons hit something which made the mower stop running. I was told that I needed to replace somesort of key...? How...? How do I get the top off....
Dec 07, 2009 | Toro Lawn Mower With Toro Power Tools
Good Day.
Oct 07, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Quit self propeling stopped suddenly while mowing
Probably needs a new belt. this happens when you use it alot!!
Apr 11, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 20073 self propeled, walk behind mower-how to replace belt ?
4. Remove the blade
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
