Question about Brother Cell Phones
TRACFONE LGL 15G - Trying to help brother with phone. 1. No way to turn camera flash on. 2. How to move apps or media to SD. THANKS
  • 13 Answers
SOURCE: Adding SD card to my ILO
What, you actually hotwired a flash card into the Ilo? Impressive. Or are you trying to get the Ilo to play music from an SD card, when you have both plugged into the computer? If you're talking about the first, then I'd say you did a good job at NOT destroying your Ilo. If its the second, then unplug your Ilo, put your headphones into the headphones jack in the computer, and play the music from your computer.
Posted on Aug 28, 2007
Benimur
  • 6966 Answers
SOURCE: vaio and micro sd
Appreciate the direct "Ask Me".
Since you have verified that the card works (in your phone) and that the adapter works (in another computer), then the issue could very well be with the Sony VAIO VGN-C140G/B. More specifically, the USB ports/drivers. Presumably that the Sandisk 2Gb Micro SD & the adapter were working before and that you are using Windows Vista, pls check your updates that has anything to do with USB. Alternately, you may want to rollback/downgrade the USB drivers and/or seek USB driver update from the Sony site rather from Microsoft.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for your continued patronage of FixYa.
Posted on Sep 13, 2008
SOURCE: unable to set time and date on Sumsung t301g Tracfone
I had the same problem. I had the phone on when I called to set up initial service. After activation I left it on (it was charging) and tried to set time and date but couldn't get anywhere. Finally, I turned it off (hold "pwr / end" button till it turns off). When I turned it back on I got a message that time and date were now automatically set. This was about an hour and a half after intial phone call. Don't know if that wait time had anything to do with it.
Posted on Jul 15, 2010
  • 170 Answers
SOURCE: DXG-565V Flash Media Camcorder: my DXG -565V Flash Media Camcorders sd slot wont e...
There is a spring that puts pressure on the SD card. It is most likely stuck.
You will need to fish around with a straightened paperclip, but be careful not to bend anything or the slot won't work properly any longer.
this has happened to me a few times and it's always the same fix...the spring is jammed and needs to be coerced back into place.
Hope this helps!
Posted on Jul 19, 2010
cinek79
  • 320 Answers
SOURCE: moving apps onto sd card
Hi in order to move apps to sd card you need place the sd card in your tablet go to settings then applications. On the next screen you've got the list of downloaded apps just clik on one of them and then properties screen come up on which in the second row you will see button move to sd card. Just press on it wait few seconds and your apps is moved. Repeat this for every app but bear in mind that some of the apps can't be moved to sd card Regards
Posted on Dec 26, 2013
How do I move apps, pics, etc to SD card? Internal storage is full
For Android users, get the app Android Assistant and run it, use the Tools tab and choose the tool named "APP2SD" and choose an app from the list. When the app description appears, click on the STORAGE button and then click on CHANGE and click on SD to move the app from "Internal" to "SD card". Wait for the app to finish being moved, then back out to the list of apps that can still be moved to the SD card and do the next app. Be aware that when apps get updated, they will move back to the internal memory, so I usually check with APP2SD about once a week and move things as needed to my SD card. For space on my SD card, I chose a 128GB micro SD card and I've only filled it about 1/4th of the way over the past year. This is the safest way to move things because Android Assistant will only list the apps that can be safely moved to the SD card. Some built-in phone apps must stay on the phone's internal memory to keep working, and those cannot be moved and won't be shown by the APP2SD tool.
The Android Assistant also has a "Cache Clear" option on the Monitor tab that helps free up internal memory on your phone when you run it (cache clear). The app (Android Assistant) may tell you it needs access to stuff so it can clear the cache. Do what it says to give it access, then go back and tell it to clear cache and it will free up some more internal memory. Cache items will be refilled as and when each app gets used, so if memory runs short again, you might need to do this "as-needed".
I paid the cheap price for Android Assistant Pro so I wouldn't accidentally click on advertisements that pay for the free version. It find the app very helpful.
TIP: You can also set MANY apps to PUT their things directly to the SD card instead of internal memory! Yay! I did this with my camera app and it REALLY helps by having photos and videos sent directly to the SD card so I don't have to keep moving them around.
Jan 07, 2018 | Tablets & eReaders
Cell phone has insufficient storage to download app 6ya. Need answer for R472 Zenith radio. Can someone help?
If your phone has provision for an SD card, then, you just might be in luck.
Step 1:
Insert an SD card and confirm that your phone can truly see it and in turn access it.
Step 2:
Navigate to Settings, then click on Apps/Applications
Once this opens up, scroll to identify app you downloaded and installed on your phone; especially the ones with high ~Mb sizes.
Step 3:
Select or click on one of these apps. A page opens where you'd notice app info
**Force stop
**Uninstall
**Clear app data
**Move to storage/Move to SD card
Step 4:
Click on "Move to SD card/Move to Storage"
Do this for every app you installed and get them transferred to the SD card.
This will free up internal memory space so you can install new apps on your phone.
Oct 11, 2017 | Cell Phones
Cannot download anything, insufficient space on device
Hi Izabel Maritz, I want to help you with your question, just answer each of the following to the best of your knowledge and follow the solutions. 1 Smartphone or not. 2 Removable media inserted? (Micro SD card) 3 Does the Removable media device show unused space? First and most importantly if you know a Micro SD card is installed with sufficient space to save your downloads then your phone settings are set to save downloads to 'local storage' and has filled to it's max. Often you can fix this easiest by removing the card for a few seconds and re-inserting it whilst the phone not 'locked'. Most phones will prompt you asking if saves should now be made to the SD card or to leave it at 'local storage' If you answer yes to each of the above numbered questions, it is likely the browser you are using is set to download to the incorrect destination. Try Solution A below. If answers no to questions 2 or 3 of the above question skip to Solution B. (Solution A) To check this open your browser and look for the settings menu. From here it will depend on the browser you are using, but you want to look for an option related to the following. 'download location' 'file destination' 'save to external media' If you have no success or need help finding the setting for your browser please provide me with browser name. If it is the cell phone provider browser that comes default on the phone then I will need the make and model of the phone. (Solution B) If no Micro SD card is installed to your phone I would recommend buying one they are inexpensive and provide a large amount of space for things on your phone. The average phone whether it is smartphone or not does not have much 'local storage' Other solutions for B, 1 Freeing space in your local storage. This means deleting things saved to the phone itself. Music, Pictures, Ringtones, Video's, Applications could be filling the phones local storage. 2 Freeing space on your 'external media' device. This means deleting things from your 'Micro SD card' (Note. If you plug a phone smart or not into a PC or laptop usb port you may move things rather than delete them. I can assist further with that as well.
Nov 25, 2014 | Cell Phones
How to set memory card as default memory storage
Download Titanium back up. it has all you need you can move all the apps to sd card including built in apps (the ones that can not be unistalled)
Caution: your phone has to be rooted juts google how it can be done in case you are not rooted yet. and be carefull while moving apps some apps can cause damage to your phone if moved to sd card. just move the downloaded ones and some few like photo viewer, galary, music player and the like
Nov 13, 2014 | Nextbook Tablets & eReaders
I have a UMX U670c phone thru tracfone, it keeps telling me i have low space but it won't let me move any of my files to my SD card. What do I do?
Visit this help page: http://tracfone.deviceanywhere.com/net10/home.seam?custId=NTUXU670C
and select the 'Memory' item in the left menu. It has instructions for deleting data and apps and moving apps to your SD card.
Perhaps your SD card is also already full ?
Jun 25, 2014 | Cell Phones
Samsung galaxy S3 phone camera not working..When turn on camera,no other function button on screen works & it says "camera failed"..any help? Many thanks :)
Let me guess.. you are using an external SD card, correct?
And, now you are having this camera failed issue. It's due a corruption with the SD card.
1) Go to Settings>Application Manager>(swipe right to left until you see) ALL>(Scroll down the list to "Camera") Tap on Camera> press "Clear Cache".
2) Power off your phone.
3) Take the back cover off your phone.
4) Remove your SD card
5) Restart the device
6) Wait a couple minutes for the phone to fully load. Then, re-insert the SD card.
The camera issue should be fixed.
7) go to the camera app, in the camera settings change how the camera saves photos to phone storage only (NOT to SD card, this is where the problem occurs). Doing so will help the camera take photos faster. The SD card is too slow for the camera. After taking your photos, you can move them to the SD card to clean up space and back up your photos in case your phone ever crashes or you ever become locked out of your device. I would use the SD card to back up all files not just photos.
Apr 12, 2013 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Can't transfer my music to LG800g micro SD card. It will go to internal memory only.
you have to download a file moving app or viewing app. it should allow you to copy the music files on your phone and past them to the sd card. This may work but if not you may have to reformat your sdcard and but that will wipe everything on your card. Another solution is to get your phone rooted is what you may have to do giving you acess to move files around better
Oct 19, 2012 | tracfone.com
I have an HTC Desire on T mobile in the UK. I have the new froyo system but cannot move any apps to my memory card. I have only 6 apps running and my internal memory is getting low to a point where I...
searcht eh android market for apps 2 sd or similar, then install and it will move all apps that can be moved to the sd card, some of the file statys ont eh phone however.
also completely clear your internet history and cache.
Jan 18, 2011 | HTC Desire Cell Phone
Cell Phones Logo
66 people viewed this question
Top Brother Cell Phones Experts
Andrew Taylor
Andrew Taylor
Bill Boyd
Terry
Terry
Are you a Brother Cell Phone Expert? Answer questions, earn points and help others
