Question about Lexmark X1270 All-In-One InkJet Printer
When we put paper in the printer it goes cricked
The paper goes cricked
  • 250 Answers
Paper goes cricked due to the following reasons
An overheated fuser is one of the most common causes of a paper jam. When large loads of print jobs are pushed through a printer, the fuser slowly starts to warm up. As the fuser warms up, the heat causes the corners of the printer paper to bend. The hotter the fuser gets, the more the paper bends. Eventually the paper bends so much that it causes the paper to get stuck in the fuser, causing a jam.
Certain paper types are only made to be used in specific printer types. One of the reasons for this is paper thickness. This is especially the case with bonded paper. If the paper is thicker than the printer is able to handle, jams will occur either from not being able to enter or exit the printer, or by grabbing more than one page of paper at the same time.
Torn paper from passed paper jams may also cause future jams. When removing a paper jam it is important to ensure that every part of the caught paper is removed or else a single remaining piece could block the paper trail and cause a jam.
If you cannot find any other reason for a continuous printer jam, the problem may be the roller. A cracked roller can easily grab a piece of paper and get it caught. A glazed-over or dirty roller can also cause the paper to get caught on the roller and jam the printer. If the roller is cracked or glazed, you may need to call your print technician or replace the roller.
1.Carefully remove all of the paper that you see that is jammed anywhere first. Also open all of the paper drawers and remove any jams. Make sure there is no bent paper left in the tray
2.Open the doors on the copy machine and there is usually a series of knobs and handles that you can manually turn. These knobs ar4e usually bigger and a bright color. Follow the direction arrows and turn all the knobs, one at a time to manually move any paper that is stuck. If you hear paper thrashing around stop turning and see if there is anyway to remove it without tearing it further. A lot of the components can be pulled away from the copy machine so that paper can be taken out. Be careful though because the internal parts of a copy machine can reach 400 degrees or more and you can easily get burned. If you don’t feel comfortable doing this part of the step than don’t do it. Usually you will be able to turn the knobs to get the paper jam to feed through without having to open the components though.
3.Check for small pieces of paper. Sometimes tiny bits of paper or even paper dust can cause the copy machines sensors to misread or even cause a paper jam. Try using a duster or even just blowing a little near the paper feeds, copy glass, and where the paper comes out.
Posted on Jul 25, 2009
    Problem Solver:
  • 12 Answers
Lexmark printer have paper roller problem take printer for once service
Hello, i have a HP Officejet Pro L7480 which did not cause trouble for 3 years, but now: PROBLEM WITH PAPER FEEDING - when trying to print something, the printer normally "tries" to grasp a...
Hi
If it attempts to feed and expecially when you hear a cricking sound. It means that the paper guide it too tighten that it holds the paper. Try to loose up the paper tray guide. Are you using a paper tray. If not, put small paper or change the correct setting of the paper size setting to auto detect if any.
The try to print again.
Mar 31, 2011 | HP Officejet Pro L7480 All-in-One...
No problem, but don't know if the print goes face side up por down into the printer when faxing
Where you put the paper must be a little icon like a page with lines, if you see this put the paper face up. I am surprise you did not check with a fax recipient to see if they got it (Blank paper or the fax)
Mar 18, 2011 | Office Equipment & Supplies
How do i put the paper into the printer?
The non-perforated side goes into the printer, glossy side up.
Jul 12, 2009 | Canon Selphy CP510 Thermal Photo Printer
My printer keeps saying I have a paper jam, but after inspection I cannot find any paper that is jammed. I also put the copy paper in the correct tray, however when I try to do any of the all-in-one...
usually you have to look at the sensors trough were the paper goes (a small pice of plastic that is suposed to move) maybe you have a blocked sensor.
Jun 14, 2009 | Dell 926 All-In-One InkJet Printer
How to put photo paper inLexmark Z2300
Photo paper goes in the same spot as normal copy paper.
Jan 06, 2009 | Lexmark Z2300 InkJet Printer
Paper goes through the printer as though printing but paper comes out blank
Just make sure the cartridges are not running out of ink. Try with different carts, It should work fine.
Apr 20, 2008 | Office Equipment & Supplies
Paper not feeding into the printer properly
This is usually caused by the pickup rollers. When they get worn just a little they will start doing this. You can try cleaning them with alcohol, this helps sometimes.
Mar 21, 2007 | HP DeskJet 450wbt InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
337 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
