Question about Lands Phones
Change stored number on the edge 120
I am looking to change my answering service number that is stored and I can not get it to change
Change a serpantine belt 120 parado
double posted and again, with no engine number
they had 7 engines
and 2 V6,
name one.
back up one post. i put up a generic answer,
despite no engine or YEAR stated. (nor country)
Feb 21, 2014 | Toyota Land Cruiser Cars & Trucks
How do I change the light bulb in my Advantium Micro Wave. Model is a 120 number SCB1001KSS01. Please send me instructions. Thank you. Karl kflorian5@gmail.com
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 01, 2011 | GE Advantium 120 Convection/Microwave Oven
Which way do the rings need to be facing on the piston for a 2002 xr 200?
first be sure to place the rings in the cylinder and check to see there is enough ring end gap so they do not bind when they get hot. The numbers/letters face up. The gaps should be placed around the piston so they do not line up.(120 degrees for the oil rings and 120 degrees for the upper and lower scraper ring plates) Of the upper two rings the lighter color ring goes on top, it should have a rounded edge top and bottom. The second ring usually will have a bevel , scraping edge down ( again numbers/letters face up). Before installing rings be sure to roll the ring around in the ring groove to look for binding spots. If you find a tight spot , use a point file or fine cut file to clean it up. be very careful when you install your rings so do not bend or break them.
Oct 23, 2010 | 2002 Honda XR 200
How do you change the inside light bulb in the advantium 120 mocel # sca1001hss01? The cooking is fine, the speedcook light works. I just need to know how to change the interior light
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
But bulbs can usually be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jul 14, 2009 | GE JVM1650 1000 Watts Microwave Oven
Need to erase numbers stored on speed dial
Go to uniden.com and look in customer service/manuals. They may have it to download. You'll need the model #
Mar 26, 2009 | Uniden Cordless Phone
Maytag microwave light bulb MMV5207BA/BC
A 20W, 120V replacement xenon halogen bulb with G8 base can be purchased from Lowe's.
Aug 20, 2008 | Microwave Ovens
Address book disappeared
I could not find the exact manual for your phone, but this one looks close and has instructions for programming the memory: http://www.conairphone.com/IBs/caller_id/cid200.pdf It says: BASIC MEMORY PROGRAMMING The CID200 comes with 10-memory dialing. NOTE: Your local phone company restricts the time you can have the handset off the base (off-hook). YOU SHOULD PROGRAM THE CID200 MEMORY WITH THE LINE CORD UNPLUGGED FROM THE WALL, IF YOU ARE GOING TO PROGRAM MORE THAN ONE PHONE NUMBER. Press [STORE] to enter memory store. Press the keypad to enter the number that you want to program. Press [STORE]. The ?MEM? will be displayed on the right corner of LCD. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. Copy from the Caller ID to Telephone Memory Press [Up Arrow] or [Down Arrow] until the Caller ID memory location to be copied appears on the LCD. Press [STORE] twice to enter memory store. The ?MEM? will be displayed on the right corner. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. If no key is pressed within 20 seconds, the LCD will return to ?Answer-Ready? mode. Repeat the above steps to store a different number in the same speed dial location, or to store a new number in a different speed dial location. NOTES: ? Pressing [PAUSE] will place a 4-second PAUSE into the number. Which may be required for accessing special phone services. ? You can store a number with up to 16 digits maximum. Only the last 14 digits will be displayed.
Mar 15, 2007 | Conairphone CID 244
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
