Question about Thermador Ovens
Can't remove hinges on thermador scd272T oven. There's no screw holding them in place & it seems like the hinges need to be open to remove then. Can't get them open with the door removed & taken apart
SOURCE: How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Posted on Nov 15, 2008
  • 1462 Answers
SOURCE: Neff Oven Door Removed Incorrectly
you need to lock the hinges to get the door back.
it needs some strength
lay door flat on floor
force hinge against the spring until right back and put the locking arm over. i use my feet for this!
Posted on Nov 29, 2008
SOURCE: thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Posted on Oct 13, 2009
SOURCE: Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Posted on May 16, 2010
SOURCE: Thermador oven door won't close all the way -
Have exactly the same situation. All the solutions I have seen talk about replacing the hinges or seal. But people report the same thing happens a month later. Looking hard at the door what it needs is something to pull it right at the top. So I installed a rare earth magnet from www.kjmagnetics.com I used part number BX884DCS which costs $4. It mounts with a couple of screws and I put it on the door a couple of inches down from the top.
Its possible that heat from the oven will kill the magnet over time but for $4 I can replace it for a lot less than hinges and it works great. The door closes more securely than it ever did when the oven was new.
Hope this helps.
Posted on Jan 26, 2011
I have a gmc275pd, and need to remove door to replace the inner glass. can't figure out how to remove the door, there doesnt seem to be a locking latch that others describe on the internet.
Open the door look at the hinge where it goes into the receiver you should see a small hole place a small short screw in the hole each side now close the door slowly hold the door while closing you should feel the hinges release out of the receivers, to take the door apart you are going to have to remove these screws to do this take the box end of a wrench pull the hinge back to take pressure off screw remove screw
Feb 11, 2015 | Whirlpool GMC275PD Electric Double Oven
Remove oven door from hinges
the door is removed with the hinges in place. with the door open, lock the hinge sections together with the little clips on lowest hinge section. When locked, lift up on the door (not the handle) sides, swinging it up until it can be pulled out. Install in reverse order.
Feb 17, 2014 | Thermador Ovens
The door will not close completely
Hi someone lifted up on the door this ishowyou remove oven doors open the door about 1/3 then push down towards the floor it should go back into place, if not you may have to remove it clean the hinges then re-install it , I don't think anyone could have bent the hinges cause that would b very hard to do, but i have seen it done before , get back to me Frank
Dec 04, 2011 | Thermador Professional Series PO301...
I have the SC272TB Double Oven. The top oven is fine but the lower one will not stay closed. Whether baking or not, the door seems to pop open just enough to turn the light on. We walk by and press the...
Welcome to FixYa.
Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges.
Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
The issue with those Thermador wall oven and freestanding range doors ( especially on the freestanding "professional" line ) is the weight of the door is so great, the hinge will actually move slightly over time, other times the entire hinge will need to be replaced.
This is what I'd recommend ( also official Thermador remedy, rest assured as I am a authorized factory trained Thermador service provider ) before pronouncing the hinges need replacing though.
**This does require a somewhat involved repair, so if you don't feel completely comfortable or have any reservation to trying this, please call in an local authorized Thermador ( B/S/H/ ) service provider.**
Recommendation: Adjust the door box hinge per instructions below.
1. Pull the oven away from the wall about 12".
2. Remove the hinge box cover plates.
3. Remove the vertical side trim piece. It covers one of the screws that must be loosened.
4. Loosen the 4 screws that secure the hinge box.
5. Place a rolled up dishtowel at the bottom of the door and close the door and apply light pressure to the door while re-tightening the four screws.
See fig below
6. Re-install the hinge box covers & side trims.
7. Re-install and secure the oven.
That should do it, ( or as stated, improve the situation ) if the hinges are too far gone they will need to be replaced unfortunately.
Let me know if you require further assistance or if indeed this solved your problem.
Thank you for choosing FixYa today and good luck going forward.
Regards,
Macmarkus :)
Jan 26, 2011 | Thermador C302U Electric Double Oven
Is there any way to tighten this door up ,the one i have comes down just a little and the light comes on
Hello, Welcome to FixYa. Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges. Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
See fig below
Regards,
Macmarkus :)
Jan 06, 2011 | Thermador SEC271BS Stainless Steel Single...
I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
  • Screwdriver
  1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
  2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
  3. Step 3 Place the door on a flat surface such as a table or the floor.
  4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
  5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
  6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
  7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
Jul 24, 2010 | Ovens
Removing the door from a thermador oven CT130
Usually you will find a hole in each hinge to hold the hinge open when removing the door.
It is impossible to fight the door hinge springs and remove or install the door.
One opens the door and puts a nail through the hole to keep the hinge open for each hinge.
Feb 20, 2010 | Thermador Ovens
From door on range came off when I tried to lift up the range by the handle to slide it out. One of the hinges is hard to get back in place. There are two metal tongues on each side of the door. Is there...
Normally you force the hinges open and there will be a small hole to stick a nail in to keep them open. It is VERY hard to install the door if the hinges are trying to close it. You hold the hinges out with the nail while you install the door, then release the hinges to close by removing the nails.
Aug 11, 2009 | Thermador Professional Series PO301...
Thermador oven door won't close all the way - seems like the seal is holding it open. I can press and hold it closed, but if I release, it pops out. The oven light stays on all the time. Model smw272
Hope this helps.
Aug 05, 2009 | Thermador SMW272 Electric Double Oven
Thermador oven (c301u) door hinges weak, how to install new hinge
Good luck!!
Jan 18, 2009 | Thermador C301U Electric Single Oven
Ovens Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
