Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works but temp in refridge wont stay cold
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Sounds like yout defrost timer is fryed and probably your thermostat also replace thermostat first and see what hapens 20- 30 bucks thermostat behink knob in fridge
Posted on Jul 25, 2009
Hi, freezer working but refridge part is not staying cold
Most refrigerators take cold air from the freezer and move it with a fan and duct work to the fridge section. You could have a blockage in the duct, usually ice buildup, or your freezer fan has stopped working.
Jun 02, 2015 | Refrigerators
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
MAGIC CHEF REFRIDGE
What is the complete model number of your unit?
Dec 04, 2012 | Magic Chef Refrigerators
Side by side kitchen aide 48"
What is the model number of the unit?
Nov 12, 2012 | Refrigerators
Kenmore Elite bottom freezer, model number 596.76522500, Serial Number 10310256GL. Water dispenser on the inside left of the refridge. Water dispenser is not working, items are frozen in refridge. Ice...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
Refridge is not cold freezer is fine
You have ice on the temp control door that has blocked air flow. You will need to pull off the back inside panel of the freezer and de-ice it or have a tech do it and test the defrost controller. That is most likely the reason for the freeze up in the first place. Hope this helps. Good luck.
Jul 07, 2009 | Refrigerators
Freezer section is working but refridge not very cold.
check the vent that lets air from the freezer goes to the refrigerator. A control knob operates the amount of opening through the vent with a flap. makes the flap is not stuck, and responds to the knob, this is all mechanically link.
Jun 30, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
371 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
