Have a Crosely washing machine sounds like a bearing going out on the spin cycle
  • 207 Answers
SOURCE: Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Posted on Apr 11, 2008
  • 1073 Answers
SOURCE: washing machine not draining and spinning
check the lid switch
Posted on May 01, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
  • 3463 Answers
SOURCE: in spin cycle, there is a loud metal on metal
Remove the drum belt, and spin drum by hand.
If it feels rough, or it is noisy, then drum bearigs have failed.
Please rate my solution.
Posted on Jul 24, 2009
Loud noise during spin cycle
Yes unfortunately. but it's not terribly difficult to do. There are many how-to videos online
Mar 16, 2015 | Maytag Bravos MTW6600T Top Load Washer
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
Jul 25, 2010 | Amana Washing Machines
High pitched sound during spin cycle
That machine doesn't have a belt. It is more likely that you have a bearing going bad. You may also have a tub seal starting to go which then leaks water onto the bearing, damaging it.
Mar 07, 2010 | Washing Machines
I have a kenmore washer model 41743042200 when it is in the spin cycle it sounds like a bearing is going bad. Can someone confirm what the problem may be. Washer works and sounds normal in all other...
The washer may emmit a low whisteling sound during the spin. It is causd buy the air whisteling thru the holes in the wash drum. The bearings are not easily serviceable, you can check them by grasping the agitator and shaking it slightly back and forth. If you feel a little clunking then you may need the spin busnings replaced ($15-20 parts and a $80 tool)or a new machine.
Nov 21, 2009 | Washing Machines
Shaing during Spin Cycle
sounds like the bearings have worn out,to check for this open door and lift inner drum up and down if you feel like a knocking sound then this will be the bearings have worn.
Jul 13, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Washer does not drain or spin after rinse cycle is done.
Sounds like one of the contacts in you programmer is worn out or broken. That means a new programmer.
May 20, 2009 | Crosley CAWC529JQ Top Load Washer
Fisher and Paykel clicking sound
it sounds like the bearings are going out as it spins faster the noise quietens down because the bearings are more spread out and as it slows they fall lower leaving an area that it causing "friction" of a kind
Dec 27, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Feb 22, 2008 | Frigidaire FWT449
Crosely top load washer model cw20p8ws
First problem is related to the timer. It is worn out and can no longer make full contact. That is why you have to hold it in position.
Second problem sounds like the brake/clutch is dry. Most of these machines used a wet braking system. It's repairable but not cost effective.
Might be better to look into a new machine as the cost of repair may be more than the old unit is worth.
Jan 02, 2008 | Washing Machines
Maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Nov 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
