Question about Ryobi Garden
Ryobi BC30 does not spin high speed - Ryobi Garden
  • 34 Answers
Posted on Jul 19, 2009
SOURCE: Ryobi bc30 gas trimmer wont run full speed will
I have the same issues. I think the solution is to toss it and buy a real one from an actual lawn care dealer that sells quality brands. Yes, they will cost about $200 and up, but it's worth it to have something alot more reliable, and can be worked on when needed. I know I have wasted more than that extra $100 in time/effort with this thing, and I still plan to buy a new one. So now, that quality trimmer will cost more because of the money I wasted on the Ryobi in the 1st place.
Posted on Jul 22, 2009
  • 1033 Answers
SOURCE: MY ryobi bc30 expandit starts,but the weedeater
The drive may be broke. It travels from the head to the engine. The drive spindle is attached in a hole at the engine and the engine rotates the spindle to rotate the head. The drive spindle must be broke inside the shaft, the engine or the head. If this is the case, a new weedeater will be a better option.
Posted on Jun 05, 2010
  • 1545 Answers
SOURCE: Can't figure out how to remove "arbor" so I can
I just found out that the string head adaptor (arbor?) has left-handed try loosening it the other way. Here it is:
Posted on Aug 14, 2010
  • 1545 Answers
SOURCE: manual ryobi bc30 model ry30522 can i get this ?
Here is the manual for the bc30:
You will need Adobe Reader to view it.
Posted on Oct 05, 2010
Ryobi bc30 idle and run probloms; plastic ends on ajustment screws on carb keep you from ajusting carb. how can you ajust. can start with chock but will not run with chock off.
mmarote, this is what I did to solve that problem....remove carb...take a hacksaw or dremel tool and cut or grind slots straight across the centers of both screws deep enough to get a thin bladed screwdriver in the slots....turn to voila....
Jun 25, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
What is gap clearance for sparkplug on ryobi bc30
to be honest dont bother with it it will be cheaper to buy new but i would stear clear of ryobi
Jun 19, 2010 | Ryobi Garden
I have Ryobi BC30, that will not recoil. How can I fix this. I took the shaft off, then undid the screws that hold the plastic (gray) housing, but I still cannot get to the cord. How do I get in there?
You have to remove the motor from the housing. To do that, you remove the part that connects to the drive cable. Take a #15 TORX screwdriver and put it in where the cable would go. That will allow you to remove the part. Then you will see the clutch. It spins off counterclockwise. You'll have to figure how to hold the shaft while spinning off the clutch. Once the clutch if off, you can remove the motor and starting pulley. You may find the spring has broken. Get a new one and be CAREFUL putting it back in. Once the spring is in, reassemble the rest of the trimmer...Good luck...
Aug 25, 2009 | Ryobi Garden
My new Ryobi boggs down/ stalls as soon as I pull on the trigger.
You should have 2 small adjuster screws next to each other on top of the carb.Try adjusting each of them a little with a thin screwdriver as the engine is running.Put strimmer on the ground first and adjust screws while you are revving engine until it runs correctly.Trial and error and very small adjustments can make quite a difference.Hope this helps.
Jun 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have no spark on my bc30 trimmer. I have changed the sparkplug but still no spark
You probably have a bad ignition module (coil).Or, you have a wire from the kill switch grounding the plug.
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Garden Logo
Top Ryobi Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
