Question about Sony Televison & Video
I have this KDL-46V2500 Sony television. When i turn it on, the screen looks like its broken on the inside. But its not physically broken on the outside of it.
I'm trying to figure out what piece that is would i be looking for if i wanted to replace it? And if known how much would it cost to figure out to replace that piece. I believe it is the LCD portion, but wanted to double check.
    Top Expert:
  • Sony Master
  • 12,962 Answers
Screens do not come cheap. After figuring in the cost of the part and labor it might just be more cost effective to replace the set and have a new set warranty to boot.
Posted on May 03, 2017
I want a 1.8 stitch length to paper piece ... I can't figure out how pfaff creative changes to 1.8
Looks like your machine's stitch length ranges from 0-6 mm. So you are looking at something just under 2 mm--there very possibly is a 1.8 setting on your machine. Basically, your paper piecing instructions are telling you to set the machine to stitch somewhere between ~12 to 14 stitches per inch. The accuracy of 1.8 is Not that important. What they are trying to do is make sure your stitches are close enough together to make it easy to tear away the piecing paper. When using longer stitches for paper piecing, it is sometimes difficult to tear away the paper without pulling the thread stitches. Most garment stitching is set between 10-12 stitches per inch. So you want something just a little closer together, ie more stitches per inch. If you are concerned, try it out on a scrap piece of paper and fabric and try tearing it away. If it works, then that's all you need to use.
Setting Stitch Length Quick Look at How and Why Sew4Home
Mar 11, 2017 | PfaFF Sewing Machines
How much does it cost to tune up a 2004 Rendezvous?
its a loaded question as labor rates and parts costs vary greatly depending on your location.
A six cylinder tune-up should run around 80.00 - $100 for labor and figure about $7 a piece for the platinum plugs your vehicle requires, so roughly $120 - $150 for plugs installed.
If you replace the wires there may be a slight charge to install and figure about $40 - $80 for the wires.
If you happen to have a coil with a corroded terminal figure about $40-$60 a piece for coils. There are three.
If you have the throttle body, valve and fuel system cleaner done, figure about $100 - $200.
The best way to find out is to call around some local shops or a dealer and see what they charge.
Jul 17, 2015 | 2004 Buick Rendezvous
Looking for the small animial pieces for Flipper Frenzy?
ebay .,. or ask for it ubder wanted ,,, ib craigslist
Jan 09, 2015 | Wild Planet Flipper Frenzy Game
My 2000 ford taurus security alerts light come on while driving and sometime want start. I took it to ford and the gave 10 different possobilty which cost me $125.00 for nothing. I went to auto zone an...
Probably the antenna which is located inside of your ignition switch..You pull the shroud off from around the steering column and right around the ignition key,,there is a round plastic piece that surrounds the key with wires on it..Its the receiver for your security system..It reads the signal from your key and tells the computer to allow to start the car..They are known to go out on a ford
Sep 17, 2011 | 2000 Ford Taurus
I have a kenwood kvt-617 and im trying to figure out the name of a piece i am looking for. its the piece that you can remove to where the whole thing doesnt work...does anybody know where i can find one...
good day, do you want to reset the dvd player? well you may try removing the terminal of the car battery and put it back again and see if you find what you are looking for. hope this helps, have a nice day
Feb 08, 2010 | Kenwood KVT-617DVD Car DVD Player
Spilt in the rubber like piece located by the brakes
I am guessing that you are asking about a brake hose and have noticed the outer casing is splitting. If so, the cost of the brake hose are about $20.00 each and labor runs roughly 1 hour at what ever the shop rate is plus the cost of brake fluid. So if you were coming to my shop, it would cost just under $100.00 Usually if one is, it's a good idea to look at all of them. Should more than one need replacement, there is some overlap labor figured, only in the bleeding of the brakes.
Should there be some other item you have spotted in the braking system which is rubber, let me know and I'll try to address that issue.
Apr 23, 2009 | 1996 Nissan Sentra
Laptop Y510 lower case small piece was broken
You can change the lower case but I would like to know that why do you want to change because there is some known issue with the hinges of this model so you can contact to customer care and get it replaced if this is a hinges issue otherwise it will be costing you nearly 5000 Rs.
Jan 30, 2009 | Lenovo IdeaPad Y510 Notebook
Lost piece of Harness
You can get replacement buckles at Babies R Us. They are also known as harness ties. They may be available at other stores like Target etc. You can also order one from Graco, but it will be a bit pricey with shipping costs etc. -Vish
Oct 04, 2007 | Graco 8A00PSN - Pierson
Open Questions:
Televison & Video Logo
27 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
