Question about Garden
When blades engaged mower shuts off - Garden
    Top Expert:
  • Garden Master
  • 77,939 Answers
Excess drag in the mower blade drive or a clogged carburetor jet.
Posted on May 03, 2017
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ... > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from
Dec 29, 2015 | Garden
When running the mower, it shuts off immediately when trying to engage blades(pto)
Hi Digger:
I've two possibles come to mind for you to check.
1) Engine OFF - Make sure that all of the blades and pulleys can turn freely.
2) Engine OFF - Double check belt routing. Move engage lever ON/Off and look at what movement happens. It may be that the belt is on the wrong side af a mounting flange and binds when engaged.
Sep 18, 2015 | Garden
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
Bracket clutch anti-rotation
Without the anti-rotation arm installed when you engaged the PTO the clutch spun and probably ripped out the wires connecting it to the harness. This can be repaired but is tricky. If you have a Husqvarna dealer close by, it will save you several hours of labor to have them correct the problem.
Mar 07, 2017 | Husqvarna Garden
Cub Cadet Wont Start.
Is the blade engage off? On my riding mower, I shut if off and the blade was still engaged. Drove me nuts for 3 days and all of a sudden, I got lucky.
Oct 03, 2012 | Garden
Mower shuts off when blades are engaged
Remove the deck and check the blades and spindles. I suspect your issue is electrical and not mechanical though.
Sep 24, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Mower runs fine but shuts off when the blades are engaged.
This sis a micro switch issue, start by checking/replacing the seat switch, make sure the block connecter is fully pushed home onto the micro switch.
Jul 21, 2012 | Garden
I have a JD 160 mower that shuts off when you turn on the pto switch for the blades, I have checked the charge in the battery and it is good, it will start to turn the blade and then the engine dies, just...
Most likely cause is the seat safety switch is not functioning properly, ie. when sitting in it to allow blades to engage, if failed it will act like there is no one on the mower and the blades get engaged it will kill the engine, like having the ignition shut off.
I hope this is helpful to you.
Aug 10, 2011 | John Deere Garden
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
