Question about Refrigerators
The Freezer is turning on and then off. It makes a clicking sound near the compresor
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
It is a starter for compressor /clicking/, sometimes help disconnect freezer for one hour and recconect it.
It is overheating compressor.
If that help..
If not, maybe compressor is dead and starter try and try.
Posted on May 03, 2017
Whirlpool sise by side fridge mod # ED5FHEX5SNOO Whirlpool side by side: --------------Fan running -------------------------Compressor not running (not clicking) --------------------Freezer ok, FRIDGE NOT...
YOUR SAFETY SWITCH IS CUTING OF. THIS SWITCH IS NEAR THE COMPRESOR. SHOULD COMPRESOR GET VERY HOT IT IS INDICATION THAT IT NEEDS TO BE REPLEACED. IN THIS CASE SOMETIMES IS BETTER TO GET NEW FRIDGE AS REPAIRES MIGHT COST TO MUCH
Mar 02, 2011 | Whirlpool Refrigerators
Thaws out.
sounds like a compresor fult to me,,,you may need a new compresor fitted and a re/gas as well
Jun 24, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
Top mount freezer won't cool, fridge works fine.
check for compresor operation. a relay on compresor could be out
Feb 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer motor clicks on but then clicks right off again
Make sure the condenser coil is clean and the fan works (if not replace it) If those are ok probably the compresor relay is bad (no more than $30) and after you replaced the relay ,if still the compresor won't start the problem is the compressor itself.
Aug 27, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Fridge freezer not working/power ok,
If the compresor is very hot and won't start,the clicking you heard is the overload at the compresor that goes on & off beacause the relay ,that makes the compresor start is bad or the compresor is bad ,if you know how check the compresors coil if not try replacing the relay with a same replacement(no more than $20 or $30) if still won't start the compresor needs to be replaced.
Apr 24, 2009 | Refrigerators
Not getting cold, condenser dosn't sound like it's working, I hear a clicking sound like a relay but nothing turns on after the sound
If you hear a clicking sound,probably is the compresor trying to start ,if the condenser fan motor work ,first replace the relay wich is not expensive ,if it doesn't work you have a bad compresor.
Apr 10, 2009 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
