Question about Exercise & Fitness
Why is treadmill 9500 HR not accepting pass word just keeps going back to beginning press start and enter password ? HELP PLEAsE
  • 5 Answers
SOURCE: hdd master password
PLEASE REPLACE UR MOTHER BOARD BATTERY. I GUESS UR BATTERY MODEL WILL BE CR3212... PLEASE CHAGE IT AND TRY IT AGAIN. NOT YOUR LAPTOPS BATTERY... THIS IS A BATTERY ON THE MOTHER BOARD. PLEASE TAKE IT TO UR NEAREST DEALER AND GET IT DONE.. PLEASE DO NOT OPEN IT WITH ANY KNOWLEDGE.
CHEERS
AVI
Posted on Nov 05, 2007
  • 84 Answers
SOURCE: IBM Thinkpad T23 2647 Power on password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Apr 29, 2009
SOURCE: help - password lock
Push and hold the power/vol button and the pause/play button at the same time for at least 10 seconds and the keypad will pop up... the factory code is 0000. question is how to reset the unit if the password has been changed and u don't know the new password...
Posted on May 28, 2009
SOURCE: Navman S80 will not let me go passed the safety agreement
When I turn my unit on all I can see is the accept/decline screen. The unit will not load the maps. How can I fix this?
Step 1
Connect your Navman Device to your computer via a USB cable.
Turn on your device and you will see a connection screen appear.
Step 2
Wait a few Seconds until a window appears on your desktop and then select “open folder to view” by double clicking on it
Step 3
Once you have opened this folder you will need to double click on “My Documents”
Step 4
Once my documents is opened locate and files that starts with “LOG00” and also “My Mileage” and delete them
Step 5
Once the above steps are done you may disconnected your unit from the computer.
Turn your unit on and enter your main menu page 2/2 and select “Preferences” then select “Route Options”
Once this is selected go to page 4/4 and un-tick “Enable GPS data logging” and “Enable trip recording”
Your unit is ready to use and will run a lot smoother due to increasing unwanted data and freeing space to increase optimum performance. We suggest that you follow these steps once a month to ensure optimal performance.
These steps will work on the S50, S80 or S90i. If you are experiencing this issue on an S30 or any other device, please contact Navman Technical Support on 1300 628 626.
I used this personally on my S80 after it died during my work as a Security Patrol officer and I was not happy, its all fixed now and I have my Nokia N95 loaded with the same places just in case.
Posted on Jul 26, 2009
  • 82 Answers
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
Posted on Apr 22, 2010
Incline stuck at 12
please follow this steps and fix it. Merry Christmas
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 18, 2013 | Nordic Track NordicTrack - E 7.5
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
·3
Dec 09, 2013 | Horizon T203 Treadmill
Do you know Julian2's password its my animal jam account and i forgot me password
reset your machine , follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Oct 23, 2013 | Exercise & Fitness
Life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
Apr 04, 2013 | Life Fitness Crosstrainer, 9100, 9500 Rear...
9500 hr belt stops when stands on it and funny noise from machine , noise stops when adjust front tension bolt but belt still loose
see the video and proceed. This happen because the lack of maintenance schedule . If the problem remain after you did LUBE is time to replace the old board belt. God bless you
Apr 01, 2013 | Life Fitness Used 9500 HR Treadmill
How do i get the hours info from a life fitness 9500 hr elliptical
go to the MENU, and see the details.
However your must read your instr. manual and see how to enter.
God bless you
Dec 05, 2012 | Life Fitness 9500HR Next Generation...
What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Oct 15, 2012 | Life Fitness 9100 Next Generation...
    Finding total mileage and useage hours on a Life Fitness 9500 Treadmill
    unfortunately, is NOT possible, Not miles or kms in treadmills.
    You have to buy the eagle eye.
    God bless you
    Oct 07, 2012 | Life Fitness 9500 HR Treadmill Next...
    Exercise & Fitness Logo
    29 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
