Question about Grilling
Grill cover for gr2234801-mm-oo - Grilling
  • Grilling Master
  • 3,087 Answers
Try wallmart . Home depot , Canadian tire. lowes.
Posted on May 03, 2017
Patio gas grill cover for model number gr2001408-mm-00
look in Walmart , Canadian tire . Lowes, Home Depot they all do covers .
Apr 11, 2017 | Grilling
Assembly instructions for
Request from manufacturer/distributor/purchase source
Apr 10, 2017 | Computers & Internet
How to replace headlight on pontiac g6
got to pop the plastic retainer clips top of the bumper cover all way across then theres a 7 mm bolt or u can a 9/32 socket to remove bolts on the headlight then the whole assembly comes out then theres a plastic screw cap un screw that ur headlight behind there should be h11 bulb remember one closest to the grill is high beam the one farthest from the grill is the low beam
Mar 07, 2015 | Pontiac G6 Cars & Trucks
Open hood latch not connected to the opening cable
You'll have to remove the 2 8 mm bolts either through the grill or underneath.not easy but can be done
Apr 27, 2014 | 2005 Mercury Mariner Premier
My webcam cd-r king ao series is not working anymore. its f/ #2.0 f: 4.8 mm oo
Sori this can be caused by virus attack. Kindly re-install your operating system and pc drivers.
Jun 06, 2011 | Computers & Internet
I have this grill with outdoor stand.is there a cover available
Are you talking about a protective cover or the top part of the grill? If you are talking about a protective grill cover, you can get one from Mighty Covers. They have protective covers for all kinds of grills.
May 20, 2010 | George Foreman GGR62 Grill
My KitchenAid KSCS23INSS will not make ice. The
your model has the ice bucket on the door . and it uses a infred eye system . if your open door and hold the right side closed the lights can talk to each other . if the blinking is in multi of 3 . it has a problem . if it blinks reg .pattern . then itcould be icek mker it self or water valve. ( dual valve in back .. . the sensor is most common .. about a 80 .oo kit .. mm Hint . behind the grill you will find a tech sheet that will tell you the codes and how to test . **** hope this helped ..
Jan 06, 2010 | KitchenAid KSCS23INSS Stainless Steel Side...
How do you take the dash off of a chevy cavalier
-well you start by removing the covers at each end of the panel. you will see them when you open the doors, they will just pull off.
-then you will remove the defrost grill in the top center of the dash.
-there wil be two 7 mm bolts behind the grill you will need to remove
-each end of dash will have a 7 mm bolt
-open glove box and you will find three black 7mm
-hidden up left in the glove box a square cutout you will find two silver or gold 7mm bolts that will have to be removed. (these two remove the airbag cover.
-once all the screws are removed then just pull the upper dash panel upwards to remove it (be careful of the airbag itself not to puncture it)
-with the top half of the dash off you will find 4 more 7mm bolts holding the facia part of the dash.
-remove these and pull the dash towards you around the heater and radio the dash is clipped in. be careful not to crack the panel.
-reverse procedure to put it back together.
Aug 30, 2009 | 2003 Chevrolet Cavalier
Grilling Logo
258 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
