Question about Panasonic Home Theater System System
Wireless chanel clash
Hi I've got a ticking on my wireless surround sound speaker, I've changed my wireless modem's chanel, but can't figure out how to change my panasonic SA - PT860's wireless chanel, would this solve the problem? If so how do I go about doing it?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Might be a fridge throwing off a mag feild
could be a wire running right ajasent to the speaker location
try moving speaker first
like take it off the wall and move it 3 feet
any change ?
ok that didnt work
now it is wireless but so is mine and i have to power the speakers y pluging them in
it could be if the speakers are powered then the adapters might be getting old and tired
if all fails try moving the speakers right next to the reciever and see if they still hum
ps just because the dont have an adapter pluged into the wall and it looks like a vac cord instead means they just put the adapter inside
and you are in for more fun then
Posted on Jul 25, 2009
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
There is no Sound on the surround chanels (rear left and right) at Dolby Digital Mode. What is the problem?
I'm having trouble finding the manual but you can't just attach speakers and expect them to work. You need to find the SYSTEM SETUP and perform the Speaker Configuration first and define the Surround Speakers. It probably says NONE right now.
Feb 22, 2010 | Audio Players & Recorders
My wireless doesnt broadcast. im using a dlink dsl 2740b router
Under your wirless tab. Make sure Enable AP is ticked. You have named your SSID, usually the same name as your workgroup network.
In windows your workgroup is called WORKGROUP.
Chanel is set from 1 to 13
Security is set to WEP
Authentication Type is set to OPEN
Encryption key password is set to a 10 hexadecimal code.
ie: abcde12345 ( choose something you will remember)
On the device you are recieving make sure you have the same password, SSID, Same chanel as router and is set to WEP. If they are not the same then the units will not connect.
This should resolve your connection. When you first connect have the two units close to each other and reset the router. Then reset your other device. If it does not connect chect the antenna is screwed in firmly but not too tight to the router.
If it still fails then change your chanel up or down on both devices. Does not matter what channel you choose just as long as they are both the same.
Oct 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Sound problem with home theater speakers
Change both left & right TDA7275 IC
Change all the 1uf 50v capacitors related to the IC,s
Thank you very much
contact me at meganetsl@yahoo.com
thank you again
M.Fateh Almunajed
Jul 28, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I have a RX-V461 AV Receiver for my Samsung HDTV.
I don't have manual here, but try to go to Setup menu / Speaker setup / Manual Setup / Config and check if rear speakers are NOT set to None.
Nov 19, 2008 | Yamaha RX-V461 AV Receiver
No sound/test tone front front right channel
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
Sep 30, 2008 | Audio Players & Recorders
Volume on surround sound speakers not working. Sound coming out of speakers but volume when turned to maximum is very low. Please help.
Most receivers you can adjust the different chanel levels. If you refer to the manual on adjusting chanel volumes in surround sound mode.
May 26, 2008 | Audio Players & Recorders
Righ & Left Front speakers not functioning
SOUNDS LIKE HE HIT YOUR SPEAKER CHANELS 1 OR 2,,, PUSH 1
Mar 15, 2008 | Onkyo TX-SV545 Receiver
Rear speakers do not connect
Hi
Hi
Check out Dell WL6000 Setup and Quick Reference Guide - https://support.dell.com/support/edocs/acc/P121646/multlang/srg/DAO/srg_dao.pdf
Try re-synchronize the wireless link. If there is still no audio form the rear speaker, check if speaker mode in your computer is set to 5.1 channels. Click Start Control Panel Sounds and Audio Devices. Under Speaker Setting, click Advanced and select 5.1 surround sound speakers.
NOTE: The rear speaker will not have audio output if the source audio does not have surround sound.
Mike
Mar 08, 2008 | Dell WL6000 Computer Speakers
Panasonic Home Theater System System Logo
201 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
