Question about BUFFALO Computers & Internet
Dose the Buffalo Linkstation 400 Series NAS device has a built in battery for the BIOS. Because my Linkstation suddenly is unable the save the IP Address, Date & Time etc ?
  • 61 Answers
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Posted on Jul 24, 2008
  • 56 Answers
SOURCE: bios date and time problem
You need to replace the cmos battery in your computer. Theu are usually Cr2032 batteries which you should be able to pick up for about £1.
unplug your computer and open the case.
When you look at the motherboard you should be able to easily locate the cmos battery cliped onto the mobo.
Take the old battery out and insert the new one.
put the case back on and plug the pc into the mains again.
You will need to re-enter the date etc the next time you boot up, but the settings should be retained after that.
Posted on Mar 09, 2009
SOURCE: HP LASERJET 3055 Manual IP Address not saving
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Posted on Jun 01, 2009
SOURCE: IBM Thinkpad T20 CMOS Battery Replacement?
hi-- no need to take out keyboard turn over laptop and take out main battery, underneath is the cmoss battery in a yellow sleeve, it is in a black square surround with one small screw holding it in place, take out this screw and with a tiny screw driver manouvre the plastic square holding the cmoss battery out of the recess and than holding this square gentlly but firmly pull the cmoss out.beleive me it will come out, to replace just do everthing in reverse with a new cmoss battery in place.eyeball the aperture for the white connector of the cmoss and you will replace the battery.
Posted on Sep 15, 2009
  • 10406 Answers
SOURCE: My Black Armor NAS keep
Configure your network's DHCP-server to *ALWAYS* give the *SAME* IP-address to the NAS -- use the (unique) MAC-address of the NAS's network-adapter to assign a "static" or "fixed" IP-address to the NAS.
Posted on Jul 27, 2010
How do I get my Linkstation Live LS-XL 3TB - Flashing Blue Light to stop blinking?
Lets hope you did not damage it with a failed installation. (if it was firmware) If you just tried the install CD: Most of the time when you change the router (this wifi box....) you also change the IP range. If you set a fix IP on the storage what most people do you do not find it in the new network. The solution woud be a reset, or connect a PC with old IP range, change it to the new.
What do you see in the NAS NAvigator? Quote the device name pls.
Oct 13, 2014 | Computers & Internet
How to format a LS-L320GL?
Go to IP address of NAS box logon and then choose the maintenance menu in there select the drive and format
Apr 14, 2014 | BuffaloShop Buffalo LinkStation EZ 320 GB...
Need ip address for Buffalo LS-WXL Series S/N 65850124513392
To find the IP load the NAS Navigator from the Buffalo web site. It scans the whole network for Buffalo NAS and lists them all. Make sure the firewall is not blocking the software.
It is also available for MAC.
Oct 22, 2013 | Black Box IP Address Translator With...
Problem setting windows permissions on Buffalo Linkstation duo - NAS
Unfortunately, it is not possible in NAS unless it has a facility to mount LUN to windows server by ISCASI.
Jun 30, 2013 | Buffalo Technology Buffalo ls-wxl/r1 4tb
Computer cannot find LinkStation
Possible fault with the network card or the connection or finally the configuration. So the hardware issue must be checked out swapping the card from the working set. Now check the settings or RESTORE the PC to an earlier set date. Also check the settings as done on the working PC.
Dec 15, 2011 | Buffalo Technology Buffalo LinkStation...
My hardisk doesn't recognize in my computer but appear on device manager and disk managemnt
Hello raissateddy
Go to the Control panel and select " Folder Options \View " and check " show hidden files , folders and drives " .
Best regards ,
fanaudi .,
Mar 15, 2011 | Buffalo Technology Buffalo LinkStation Pro...
Laptop will not connect to wireless internet says it doesn't have a valid IP configuration. Have unplugged loads of times can get other wireless connections in the area but not mine.
In your laptop, try to put an IP Address, subnet mask, default gateway and preferred DNS server. (please see below)
IP address:
Subnet mask:
Default Gateway:
DNS Server:
note:, is where your modem or your internet is connected (or the IP Address). This is the one that is provided/configured by your Internet Service Provider.
Jun 07, 2010 | Buffalo Technology Buffalo LinkStation...
Computers & Internet Logo
23 people viewed this question
Top BUFFALO Computers & Internet Experts
john smith
Cosma Papouis
Cosma Papouis
Are you a BUFFALO Computer and Internet Expert? Answer questions, earn points and help others
