How do I save destination? - Computers & Internet
I cannot scan my documents. I got a message from Scansnap: La destination specifiee (dossier d'enregistrement des images) est incorrecte. Specifiez une nouvelle fois la destination.
Go to the settings of Scansnap and look for save folder or destination folder. The error message usually appears when the destination folder has been deleted.
Mar 28, 2017 | The Computers & Internet
How do i save destination
I assume you want to save somethng to a specific destination. You can set up a file by right clicking any where on the desktop and add a new folder. Then right click on the folde to rename to what ever you wnat to call it. When you are ready to save something, it will most likely bring up documents, change the location to desktop and the file you want to save to and click on it , then save.
Nov 16, 2014 | Computers & Internet
How to set multiple destinations?
Some garmin satnavs allow you to save routes which have multiple destinations. The 265WT does not so the only way to set it for multiple destinations is to use via points. First press WHERE To and enter your last destination. Press GO and then while that is active pres MENU and WHERE TO again. Enter your second last destination and press GO. It will ask if you want this to be a new destination or a VIA point. Select VIA point. Continue to add other destinations in the same way with the destinations nearest to the end going in first and the closest to the start going last.
It's not ideal especially as it cannot be saved for future use but unfortunately for some strange reason Garmin do not include the option to store routes on all their satnavs.
Jun 11, 2011 | Garmin n?vi 265WT Car GPS Receiver
How do I save a destination and reselect in the future
I am glad to HELP YOU!
You will find the previous destination every time when you will select RECENT PLACES/DESTINATIONS.
But if you want to have it alays as a waypoint you have to do like this: once you have input the coordinates of it just tap on that destination [to select it] and give it a name by saving it in POI/FAVORITES.
GOOD LUCK!
Apr 21, 2011 | Navman F20 GPS Receiver
SCANNING ISSUE
You need to install the complete software from HP Website or use the link belows:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1140783&prodNameId=1140778&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
After downloading and installing the complete software you need to set-up scanner.
Using steps and i m sure your issue will be resolved.
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Jun 28, 2009 | HP LaserJet 3050 All-In-One Printer
Multifuction hp laserjet 3050 conflict with hp laserjet M1522N
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
Click Update .
May 15, 2009 | HP LaserJet 3050 All-In-One Printer
All leds light on panel
Click Update .
Apr 27, 2009 | HP LaserJet 1300 Printer
Lost destination after saving it
Sounds like the internal memory battery is run down - it's charged from the AA's. Usually does not recover. Battery (the VL1220) is shown here: http://www.panasonic.com/industrial/battery/oem/chem/lith/vana.htm.
It' easily replaced once the case is open but requires a steady hand with a fine tip soldering iron. Local story started by me here.
Sealing the case up again is very fiddly - hard to make a tidy job with silicone.
Feb 22, 2009 | Garmin GPS 12XL GPS Receiver
How to program a destination
In general, once you key in an address and then select a route, the name/route will be saved in "recent destinations." If you want to use that destination, just select it. If you want to add it to "Favorites", then select "Add Favorite" and all your recent destinations will appear. Select the one you want and rename it: E.g., instead of "220 W. Walnut St." rename it "Grandma's House" and it is set.
Oct 08, 2007 | Tomtom ONE GPS Receiver
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
